Question about Toshiba Satellite A100-S8111TD Notebook
Tosiba laptop could not start not even with safe mode.
It prompted with the following messages:
Multi O Disk O rdisk O partition (1) Windows/System32/ntokrnl.exe
Multi O Disk O rdisk O partition (1) Windows/System32/hal.dll
Multi O Disk O rdisk O partition (1) Windows/System32/kdcom.dll
Multi O Disk O rdisk O partition (1) Windows/System32/bootvid.dll
Configuration/System
Configuration/System.log
Pls. advise,
Regards,
Lee
  • Toshiba Master
  • 32,281 Answers
The error message refer to system files it cannot load dur to either corrupted or missing files.
You can try to do a repair with your Windows CD install disk and if this does not work you will need to reinstall Windows again together with any drivers that Windows didn't install and your programs.
Note you will lose you data in this process, hoped you backed up your files.
Posted on Mar 03, 2009
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
Advent will not BOOT
The BOOT.INI file may be corrupt. Boot to a command prompt and rename original file c:\ren boot.ini boot.tmp. Now type edit. and insert the following script.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Save as boot.ini. Alt key gives you the menu options
You can also create the file elsewhere and copy to c:\ Remember to rename original.
Note! This is a single partition standard from factory configuration.
Oct 25, 2012 | Computers & Internet
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
Acer recovery disk download
i keep getting this on my lap top and cant get ride of it can you help me??
Multi (0)disk(0) rdisk (0) partition (2)\Windows\AppPatch\drvmain.sdb
TRAP 00000006================EXCETION================
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\WMILIB.SYS
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\pci.sys
tr=0028 cr0=80000013 cr2=00000000 cr3=00039000em32\DRIVERS\isapnp.sys
gdt limit=03FF base=0003F000 idt limit=07FF base=0003F400compbatt.sys
multi(0) disk(0) rdisk(0) partition(2) WINDOWS\system32\DRIVERS\BATTC.SYS
cs:eip=0008:0009F737 ss:esp=0010:000600EC errcode=0000IVERS\pciide.sys
flags=00010012 NoCy NoZr IntDis Down TrapDis ystem32\DRIVERS\PCIIDEX.SYS
eax=00000000 ebx=00000100 ecx=0000BB40 edx=00030715 ds=0010 es=0010sys
edi=00060D4C esi=00000000 ebp=00060E34 cr0=80000013 fs=0030 gs=0000s
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\ACPIEC.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\PartMgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\VolSnap.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\atapi.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\disk.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\drivers\fltmgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\sr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\KSecDD.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Ntfs.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\DNIS.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Mup.sys
Feb 06, 2010 | Acer Aspire 5315 Notebook
MY pc does not start anymore. I have a Seagate hard drive ST380011A. I got the message: The following fail is missingC:/windows rootsystem32hal.dll
<windows root>system32hal.dll. is missing or corrupt. â How to fix it?â The Hal.dll file is the first file that boot.ini tells the system to look for at boot. â Looking at it this way, this error message can be rather misleading. In fact the reason could be a number of things, such as: â The boot.ini file is actually corrupt or damaged, â or it is pointing the Startup to look in the wrong place. The Hal.dll file is located in the System32 directory of your %SystemRoot% which in a default XP setup is:â C:WindowsSystem32.â You can use the Dos boot disk (or NTFS Reader above) to quickly determine if the file is missing.â If it is, then you should extract it from your XP CDrom and place it in its proper location.Boot to your XP CDrom, and then choose 'r' to go to the Recovery Console.â With your XP Cdrom in the drive, issue this command:Expand D:i386hal.dl_ C:Windowssystem32â â (This assumes the CDrom is D and your System Partition is C) â If this does not cure your issue this may be due to issues in your boot.ini file.â â The boot.ini file is actually corrupt or damaged, or it is pointing the Startup to look in the wrong place. Resolution:â The easiest way to fix this is to boot to the Recovery Console and replace the old boot.ini with a new one.â Once you have booted to the Recovery Console run these commands at the prompt:Attrib -H -R -S C:boot.iniâ â â (This removes the attributes and allows deletion). DEL C:boot.iniâ â â â â â â â â â â â â â â â â â (Deletes the corrupted boot.ini file)â â â â â â â â â â â â â â â â â â â â â â â â â â â â BootCfg /Rebuildâ â â â â â â â â â â â â â â â (Recreates the new boot.ini file)If you would like to view the boot.ini file, you will need a boot disk to get to the DOS prompt.â If you have formatted with FAT32, then you may use a Windows boot disk (such as a W98 disk), but if you are running NTFS, you will need a NTFS reader boot disk, such as NTFS Reader For DOS which is available for download here.â To diagnose the problem, copy the boot.ini file from the hard drive (C:boot.ini) and open it with Notepad.â You will want to verify that the "Default=" line as well as the ARC path line are pointing to the right location.â Here is two examples of boot.ini files (ARC paths start with multi): [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Professional" /fastdetect This is a sample of the above Boot.ini file after adding another partition running Windows 2000 Professional. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS [operating systems] multi(0)disk(1)rdisk(0)partition(1)WINDOWS="Windows XP Professional" /fastdetect multi(0)disk(0)rdisk(0)partition(2)WINNT="Windows 2000 Professional" /fastdetect â â
Nov 20, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have the same problem
if you are using windows xp, then follow these steps:
1) right click "my computer" icon, select "advanced" tab, click settings button towards the right of "start up and recovery" and  click "edit" tab
a notepad window appears with some text in it which reads something like this :
[boot loader]
timeout=0
default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT
modify that text to look like this:
[boot loader]
timeout=0
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT /3GB /userva=2800 /NoExecute=Op
Warning : only the "/3GB /userva=2800 /NoExecute=Op" has to be added extra else you will mess up
2) save the notepad and insert max ram, and check, if any BSOD's
if the problem persists, then it is hardware related..
Most probably one of your ram stick may be the problem child(which may be either incompatible with your motherboard or defective)
Best of luck...
Aug 28, 2009 | Lenovo ThinkPad R51e Notebook
Unable to boot into windows
what are the things that you added recently, hardware(additional hdd, memory, video card) or software (antivirus, office, etc games.) try running a hard drive diagnostics, usually computer manufacturer install a hdd diagnostics on their BIOS that you can run. hit me back on the results.
Apr 28, 2009 | Dell Inspiron mini 9 - Black , Intel® Atom...
I hit F8, here is the new error message
If this is all you are seeing, then this is not an error. What is happening here is that your computer is loading Safe Mode. This is a way to load Windows operating system without any extra software or programs, using the most basic drivers and software to load. There are a lot of benefits to accessing this mode, especially if you installed a program that stops you from getting into Normal Mode, or you have a virus that does the same. It makes it easy to troubleshoot. Here is a link to a website with a little more info:
http://www.computerhope.com/jargon/s/safemode.htm
If you load your computer normally by not pressing any keys, then you should be fine.
Mar 27, 2009 | HP Pavilion xt938 PC Desktop
Safe mode....unsafe.
Your PC is stuck in safe mode startup
I would suggest using the Windows Disk, if you have one, go through normal windows installation. At the point of installation just after pressing F8 it will detect windows exists and offer you a repair option press R to repair
Apr 03, 2008 | Compaq Presario V5005us Notebook
Typing
yaa you need to re-install OS whatever you have XP or Vista.
Thanks
Iqbal
Mar 31, 2008 | Toshiba Satellite 1405-S151 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
210 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
