Washer doesn't throw out the entire water after every wash
My washer works fine with except that doesn't throw the water out completely after every wash and rinse so it leaves the clothes wet/damped. Can someone please tell me what to do?
  • macopa63 Mar 06, 2009
    I tried everything that fixer444 told me to do and it didn't work. We did find out that one of the cycles it seems to be burned would that matter? Is there something else we can do or check?
  • macopa63 Mar 09, 2009
    one thing that I did not explained was that the cycles that we had seen where one was burned was from the timer. I think that it should be 10yrs or more - a question we know that the motor is working fine because the cycles go/run good. Please advice
    Scholar:
  • 106 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual, it may not be there, they want to send over a tech at their convenience to make more $$). Locate your filter, it is below the main tub, you need good clip grip pliers. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
If still not good you should examine your pump which comes after the filter. Rate me pl if helped.
Posted on Mar 04, 2009
  • fixer444 Mar 09, 2009
    Power plug off the mains first. Its your motor. For spin you require much more power. Check to see if the brushes on your motor are worn, there are two. If they are okay, you might have to change your motor. How old is the machine?
  • fixer444 Mar 11, 2009
    Is this a front loader? You motor may be fine, but if the brushes are worn (10 year machine) it will simply refuse to pump the water out, the motor shd be in top condition to "SPIN OUT", so check the brushes. I am leaving that to you to work out. All the best.
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Why do I get the sewage smell when the front load washer first throws the water out. Help me , it is really bad.
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open after every wash for a week. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again(warm), to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 10, 2010 | Washing Machines
MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
moffat washing machine does not remove water after spin cycle
May 29, 2010 | Washing Machines
My Duet washer works fine, except now I am finding water in the fabric dispenser tray after the wash cycle is complete.
Remove the tray from the machine and soak it in hot water for a while to get rid of deposits. Check the tray cavity for any obstructions. Hope that helps!
Sep 18, 2009 | Maytag MAH8700AWM Neptune Front Load...
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
When not in use, my washer begins to slowly fill with water.
you either have a very poor water pressure to the machine or the fill valve is not closing completely and will need to be replaced.
Mar 19, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Water inflow even after the cycle is complete
Seems to me that you having problem with water valve in this machine. Some solenoid on water valve is stock and water entering the washer even power is off.Water valve Part # 8181694.
Valve located on the top of the washer. Any questions let me know.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH3 series - doesn't spin completely
hi there,
can you supply the model # off your washer please?
Sep 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint washer , top load
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Jan 01, 2008 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
