Question about Kenmore 64902 Electric Dryer
Kenmore dryer The dial will not catch on any setting. It was accidentally taken off from behind and when replace it will not catch, thus the dryer cannot start. No wires were removed just the part with the small gear. What could be the problem?
  • rhiannonchea Mar 05, 2009
    Thank you so much!! One gear was pushing on another!
  • 686 Answers
If this worked before that part was taken off, then take it off agin and make sure that the gear is engaged with the other gear in side the timer unit re adjust and before putting screws back in try turnning dial if it engages the put screws back in and if this fails you may need new unit (timer unit) That small gear may be pushing on the one it's suppose to engage.
Posted on Mar 04, 2009
Dryer dial does not connect to setting therefore does not turn on
the teeth on the dial may be damaged? thus not engaging the dial u can always use pliers to turn it
Apr 30, 2014 | Bosch WTMC5530UC Dryer
Remove front panel on kenmore washer dryer stack model110.26182
Model# 110.88752799 Kenmore stacker washer/dryer
Q; How do I remove the front control panel? (to remove the timer dial, to replace a switch, etc)
A: reference diagram- http://www.searspartsdirect.com/partsdirect/partsdirect/printSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK1105180-00001.png
-remove four crews (#8 on diagram) from left and right sides.
-remove one screw (at #21 on diagram) from the bottom of the panel.
-remove #7 panel from the left and right side
- this will expose a thin metal catch (#9) on each side. With a small finger or screw driver, push down on the top of this metal strip where it bends horizontally. This will compress the spring (#14) and release the catch.
- the control panel will fold down now.
Jun 01, 2012 | Kenmore 98702 Stacked Washer/Dryer
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
It's not drying our clothes at all
Problem sounds like the heating element has gone out. Depending on the model, usually behind the drum. Needs to be taken apart and replaced.
Feb 10, 2010 | Kenmore Dryers
Is there a rest button on a kenmore dryer? I accidentely left some clothes on top of ther dryer while running the dryer and it shut off in mid-cycle. The top of the dryer was very hot, so I thought there...
Yes, there are - there are two switches. Thermal fuse and the High Limit switch located behind the back panel. Thermal fuse is a white fuse with two blue wires and the High limit switch is a black cylinder shaped fuse above the heating element. Good Luck...
Nov 16, 2009 | Kenmore 63942 Dryer
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Kenmore Electric dryer Model 110.8708 - brand new, worked fine for 2 days. Now suddenly the dryer door pops open on its own and shuts down the dryer. Is this an adjustment ?
Sounds like the door catch is weak. You can try to spead the prongs on the dryer catch (the metal protusion on the dryer, not the door), but be careful. Unless it's very easy to do, call the wrranty dealer for the the machine since it should still be under warranty and the catch should be replaced at no cost to you.
Apr 12, 2009 | Kenmore Dryers
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
I am trying to replace the belt but the drum is still attached to the back (I have taken every visible screw out). Should I try from the front? Is there a way of getting the drum unsecured from the back?
Dryers do not open from the back
the screws removed secure parts to the inside of the case
carefully replace them.
to opent the front of the dryer
unplg dryer
type I: maytag:kenmore stackable:speedqueen:
  • remove 2 screws from bottom of front panel, swing front panel out at bottom and unhook from dop
  • remove door switch wires from switch
  • remove front panel set aside
type II: Kenmore:whirlpool:ge:frigidaire
  • remove lint filter
  • remove 2 screws in lint filter holder
  • with putty knife or other blunt blade
    depress spring catches at corners of top cover
  • lift top cover at front
  • remove 1screw each side 1/3 way down
dryer internals are exposed and easily repairable
examine back panel to ensure that nothing is detached from screw removal
assemble in reverse order
Note:
while the dryer is disassembled, examine felts rollers and glides for wear, most common cause of belt breakage, if there is any wear, replace.
examine fan, fan housing and ducting for lint that got past the filter screen.
Oct 28, 2008 | Dryers
Kenmore 64902 Electric Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
