Question about Back to Basics 600 Smoothie Plus Work Top Blender
Greetings! I need to replace the part that holds
Greetings! I need to replace the part that holds the blade screws into. Any ideas where I can find it without having to by a whole new blender?
  • 8,596 Answers
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Oster clippers
it could be metal fatigue from the blade. Try a different blade and see if it does the same. If it is still rattling it could be your blade drive needs to be replaced. Sometimes the screws that hold the blade drive in place come lose or striped so you may need to check them.
Apr 23, 2013 | Oster Turbo A5 Two Speed Clipper - Blue
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Jul 14, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
The screw that holds the mixing blade in place sheared off. Is there a way to replace this screw?
Try bonding the sheared portions with Araldite. Once it is set try slowly to unscrew. OR if you can make a little nich in the embeded portion so that tip of screw driver can fix it. Then it should be easy to unscrew the sheared portion. Otherwise no other alternative but to replace the attachment.
Jan 23, 2010 | Kenmore Blender Single-Speed Blender
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Can't separate blade unit from jar, but managed to make it leak
Put it in hot water for a few minutes and then try to unscrew it.
Dec 31, 2008 | Blenders
Cannot remove the bottom of pitcher (the blade holder) for cleaning.
The blade at the bottom screws an abnormal way. If you counter clockwise the blade it does not work you need to screw it in the other direction.
Mar 18, 2008 | VillaWare 5785 Smoothee Bar Work Top...
Removing the plastic top service plate
if the motor is running and the blade is not turning here is a rubber coupling that has probably broken.the blender will need to be pulled apart and that part will need to be replaced . it is designed to absorb sudden shocks if something hard is hit and has broken rather than burning out the motor. there are two other torx screws holding the rest of the plastic parts after the switch assy is removed by uncliping it .
Nov 18, 2007 | Bamix Gastro 200 Handheld Blender
Back to Basics 600 Smoothie Plus Work Top Blender Logo
80 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
