Universal Serial Bus can't read flash disk - Computers & Internet
  • Anonymous Apr 16, 2009
    When I attach USB Flash,i can't see any device in my computer. But i can "safe remove it". WHat to do in that case?
  • RescueTechLA
    RescueTechLA May 11, 2010
    Are you sure it works?
    Can you test the drive in another computer?
My flash can't be seen pls help me to solve this!
Posted on Jan 17, 2010
Pls assist me to read my usb 2.0 myflash from my computer
Posted on Apr 22, 2009
Update the drivers sometimes thats all thats needed, or uninstall the flash disc and put into a different usb port
Posted on Mar 03, 2009
How to fix please insert disk into removable disk
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Jan 04, 2014 | A-Data Technology Computers & Internet
Tip
How to flash your disk [USB]
How To Flash Your Flash Disk
[ USB ] Universal Serial Bus
  • First : Open Your USB Disk ( Like The picture )
  • There are two black Ships , marked with Three codes
  • A code has 6 Numbers , A VID Code and A Pid COde
  • copy all the codes to a bloc-note
  • open this site : http://www.flashboot.ru/iflash.html
  • Write The First Code Second Code and The Third code (Like The Picture)
1) Click Enter
2) The Site Give's You A lot Of Information
3) Choose You usb Disk Data (See The Picture)
4) Download The Flash Application
5) Connect Your usb Disk On The Computer
6) Open The Flash Application
7) It give's a button written on it : << Flash /or/ Preformat >>
8) Push The Button , Wait For A minute
9) Your usb disk Will Be Flashed ;)
Fix-shad0w
Please Rate .
on Jul 07, 2010 | Computers & Internet
Cant install sdcz36-008g-b35
w7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamtion mark? ! or a Red X right click to reinstall drivers. If your computer came with a motherboard disk the drivers could be on it. If you can see your usb drive but its not working ports(com&lpt)right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts.
Nov 15, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Can't read micro usb drive
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X
right click to reinstall drivers or
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Oct 14, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Verbatim store n go usb flash drive 8 gb
w7
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
Sep 26, 2012 | Verbatim 8GB Store n Go USB2.0 Flash Drive...
Card reader is not being detected in my windows 7
hope this helps
Aug 24, 2012 | Electronics - Others
My memory card is not detected by card reader .it says insert disk in drive i:.card is detected and read in nokia phone.
Click the right on my computer and select manage.
In this category select device manager, it will display user areas.
In the last select universal serial bus controllers and click the double on your device.
Select use this device at the bottom of the dialogue box.
Dec 24, 2010 | Kingston 2GB Secure Digital Memory Card
My computer is not reading my scan disk
control panel admistrive tools,computer management,device manager scroll down to universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)or communications port or ECP printer port right click update driver
hope this helps
Nov 16, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My PC can not read my flash disk
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
hope this helps
Oct 29, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to remove if the universal serial bus is in write-protected?
TRY TEST DISK file:///D:/testdisk-6.11.3.win/testdisk-6.11.3/documentation.html
Mar 30, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Computers & Internet Logo
175 people viewed this question
David Payne
David Payne
