Question about NetGear WGR826V Router (wgr826vna)
Connected but...not I'm not quite sure how to say this. My wired internet usually works fine, but sometimes when I try to connect wirelessly, my computer tells me that my security information may be entered incorrectly. When I check my information, it's the same information I used to connect every time. I'll cut the power on both the modem and the router and when I turn it back on, it'll connect just fine (sometimes). What could be wrong?
  • Matt H
    Matt H May 11, 2010
    Are you using any sort of wireless encryption such as WEP/WPA?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
If you want to use the wireless Internet on your laptop make sure the Wi-Fi is activated on it.
Posted on Mar 08, 2009
Problem staying connected to internet
If you are connected via Ethernet cable, it works fine? Are all the computers wireless? Does the laptop change when moved? If you place it next to another Computer on wireless is the signal the same? Is this a issue that changes every day you boot the machine? Are the other machines static? Have you done all the Acer and windows updates? Has the laptop always been this way? Way to many variables, It's not a simple question to answer. That said, maybe a bad antenna in the laptop.
Dec 18, 2012 | Acer Aspire V3-771G-6851 17.3" Notebook PC
Emachine won't connect to the internet. Ethernet cable, router and modem all work just fine. problem is with computer. Check network adapters in device manager and no problem noted there. Why won't it...
first try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
Jun 02, 2010 | E-Machines eMachines Desktop PC
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Wireless router not connecting
Make sure that your laptop has it's wireless network enabled and the switch if any is turned on.
Jan 12, 2010 | Belkin (F5D7231-4) Wireless Router
Wireless wont connect properly
Are you using the windows utility to connect or one that came with the laptop wireless card ?
It is possible that the two different things are both trying to control the card and only one can actually do it !
I usually let windows do it for me and then goto control panel, administrative services, services, and turn off the wireless zero config services and disable it.
That usually ensures a more stable wireless connection.
Unless you need to have a specific IP and have also given it the DNS serever as well then quite often it is better to set the TCP/IP properties for both IP and DNS to automatic.
That should fix you up but just in case it doesnt make sure you 100% have the correct drivers for the wireless card. Some drivers nearly work but not quite and I have seen them cause problems similar to yours
Aug 10, 2009 | Acer Aspire One A150-1006 Notebook
My Netgear WPN824 v2 router won't work with my ps3?
hi, try setting a predefined setting
Ip adress : 192.168.1.200 ( or any number not used by pc )
Dns : 192.168.1.1
Gateway : same as DNS
Feb 28, 2009 | NetGear RangeMax WPN824 Wireless Router...
Wireless connection slow
Same problem. RESOLVED it by going to device manager (hold the Windows Logo key near the space bar and hit PAUSE) Click hardware tab, and then device manager. click the plus next to network adapters to expand it, then right click the atheros wireless connection and go to properties. Click advanced, then find the power save mode. click it, then chose turn off on the right.
did this and my wireless is working normal again. hope this helps.
Jan 03, 2009 | Acer Aspire One PC Notebook
No internet signal from router
To isolate the concern, it would be better to test the non working computer to the modem. If it works, that means there is a problem with the router and if it isn't then it is a problem with the pc..
If the computer works fine on the modem, you can try the following to check if the router works fine:
1. The modem should be connected to the router's WAN/Internet port.
2. The computers should be hard wired to the router's numbered port
3. On the router's setup page, go to the Status tab and check if the Internet IP address and the DNS are populated. If not, that means the router is not functioning correctly.
4. Go to the wireless tab and make sure that the SSID is customized. Make sure that the wireless computer is connecting to the said SSID.
If those had been checked and it still does not work, you can try updating the firmware of the router, reset and reconfigure it.
However, if the computer does not work on the modem. You may need to have it checked.
Sep 05, 2008 | Linksys WRT300N Wireless Router
Router quit working
How about the power light? Is it solid green?
Aug 03, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
NetGear WGR826V Router (wgr826vna) Logo
32 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
