Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Clean cycle does not work.
Micro switch on locking handle does not work. Also, the vent fan shuts off intermittently, I believe it is going off on the fan motors' thermal relay.
I have a service contract with PSE&G, the utility company in New Jersey. The service tech they sent over claims the parts to fix these problems are no longer available.
Can you help me locate these parts?
    Problem Solver:
  • 7 Answers
My tech guy says the relay control [circuit board ] is bad. Replacement part 12001689 costs about $220 (lowest cost I found) plus service call for your locality. I decided to get a new {NOT Jenn Air}.
Time to get a new stove. repair record not good.
Check Consumer Reports ..your library will have a copies. Look in index for Range, stove,etc.
Best wishes.
Wib411
Posted on Mar 15, 2009
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
What does it mean when the caps lock light and num lock light flash and the computer beeps?
If your cap lock light blinks on and off, and your machine is beeping at you, it means you are about to shut off for overheating. Clean out your vents, grease your fans, and see what happens. You may have intermittant fan failure, with a fan about to stop functioning, or maybe its not working at all.
May 03, 2012 | Sager Computers & Internet
Oven shuts off 10 minutes into self clean cycle or while broiling
check for loose connection on the door sensor or micro switch you ay need to change the micro swich if faulty
Jul 28, 2010 | GE 30" Built-In Single Electric Wall Oven...
My Kenmore dryer (model # 417. 93142201) has intermittent heating
There are times that the electrical code is not followed and dryers are wired into two 15 amp breakers rather than one 30 amp breaker. If two 15 amp breakers are used, they can be tied together. All that leads to a possible solution, check to see if you have two 15 amp and if both of them are turned on.
Jan 25, 2010 | Dryers
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Indesit DG6100W dishwasher will not work
It sounds as though the micro-switch inside the lock mechanism is displaced.
Undo the 6 screws at the top of the door (on the inside) and remove the outer pane. This will give you access to the lock mechanism. Please switch it off first.
The micro-switch can then be adjusted so that when the handle is released, the switch engages (you should hear a very soft click).
Hope this helps.
Jun 20, 2009 | Dishwashers
I have a 1977 450SLC. The battery was dying every third day, so I had the alternator replaced. Now the car alarm has disabled the vehicle and I cannot get it to start. The driver's side door handle was...
Yes there is a micro switch in the handle that lets the factory alarm know what position the lock is in. You can unplug the alarm control unit and do away with system. I would if it was my car. I believe it is located in the passanger side under dash panal.
Apr 11, 2009 | 2008 Mercedes-Benz Mercedes Benz C Class
Worked Off & On if you wiggled the door or
There is a internal locking mechanisim that has 2 or more switches that is usually attached with two or more screws next to the door latch side. Crack open the micro and adjust this by shutting the door then pushing this assy toward the latches untill all the switches look like they are being pushed in fully. If this doesn't solve the problem one of the switches or possibly more are defective. Call a local appliance repair center and get a switch there called micro switches.
Sep 15, 2007 | Goldstar MV-1501 Microwave Oven
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
85 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
