Question about Whirlpool Duet GHW9150P Front Load Washer
Bad vibrations The rear drive wheel on the back of the drum ,strips out and ruins the belt. I am on my third set.Any ideas other than trash it.
  • My reply is May 11, 2010
    How old is the machine and has it had a lot of use?
    President:
  • Whirlpool Master
  • 2,651 Answers
Befoer you trash it, check you warrantee info, soundsa s if you have a bad rear bearing. which requires repacing eht back half of the outer tub, as well as a new inner basket, pulley and belt. reason ofr checking is its possible to have extended warr on some or all of theese parts. you ll pay labor to get it done but may save something on parts( over 750 without part warr)
Posted on Mar 03, 2009
Shakes at 65mph had tires balanced also I cant feel it in the steering wheel it feels like it's coming from the back passanger side or middle
put tires from rear up front and front to rear and see if tires cause a shake also make sure no debris on hub so rim sits flush if no change and still vibration check drive shaft and u joints
Jul 27, 2016 | 2003 Chevrolet Tahoe
Vibration between 25-35mph only in DRIVE (automatic)
U joints get worse as speed increases. You can try replacing the mount for the transmission it may help. Also check to see if the drive shaft is damaged.
Mar 18, 2014 | 2005 Toyota Tacoma
Severe vibration from engine
If it makes the mirror blur without driving the wheels, then I would say main bearing issues.
Jun 08, 2017 | 1998 Ford Explorer
My dryer is making a very loud rumbling sound now when I turn it on. It's still working, but obviously needs some repair. I'd really appreciate your help! Thanks, Bridget
The drum on some dryers are driven by a rubber covered wheel beneath the rear of the drum. When the dryer is at rest, the drum sits still on that wheel. The longer the dryer sits still, the more the drum pushes down on that wheel and eventually causes a slight indentation in that wheel. When the dryer runs and then stops it sits at a different spot on the wheel. After a number of years of use, this wheel gets a number of these indentations and as the wheel ages the rubber loses its ability to return to its' original shape and causes a "bump" as the drum contacts these indentations. Enough of these "bumps" in a row sets up a vibration causing a rumbling sound that gets worse and worse. The vibration in my Whirlpool got bad enough to move the dryer around the floor.
There is a kit available to repair this problem for around $35 that consists mainly of a new wheel and belt and it is fairly simple to do.
Jul 03, 2011 | Dryers
1999 F250 4x2 - was stored for 3 months and when I tried to move it - the right rear wheel turns but the left rear wheel won't turn. Took off the brakes and caliper - still won't move. I can move...
Hello, The rear rotor has 2 sets of brakes on it. The other thing is to look for slight movement in the driveshaft when it clunks. Depending on the rearend, some have to have both rear wheels off the ground to turn each side. And of course the trans in Neutral.
With the rear wheel you have an Emergency brake and a drum brake inside the center of the Rotor.
The rear of the brake backing plate has a rubber plug which is covering the Star-wheel adjustment for those drum brakes. You can try to loosen the Star-wheel to disengage the Emergency brake shoes. You can try pulling the brake cables toward the cab, to loosen the cables.
If this does not help, your Emergency brake shoe probably rusted off the brake mount and is jammed inside the drum. The linings fall off the metal like banana skins. I can tell you that if the Emergency brakes are a State safety requirement, you need to consider new rotors because the drum portion is usually trashed with rust.
I hope my Solution is very helpful to you.
Jun 11, 2011 | 1984 Ford F 250
Model #: GE DRSR495EGWOWW metal on metal scraping sound bottom of drum top of lower lip, near blower motor. Cannot seem to identify exactly what is causing this. Things I have done: replace the glide...
check the felt strip,i've found screws,pennies,nuts and bolts stuck into the felt strip or the blower wheel is scraping,usually it's the rear gearing,the sleeve wears down part number WE1M462 and it's like 12 dollars
Apr 24, 2011 | GE Dryers
2002 Caddy DeVille - slight vibration 60 to 75 mph
I would guess incorrectly tightened or installed wheel bearing. Or it might just need to get greaced.
May 15, 2009 | 1983 Cadillac DeVille
1984 lincoln town car has noise and vibration only when turning coming frm the back of the car.
Lots of things to check. Rear wheels, lug nuts, loose suspension piece, rear wheel bearing, since this is a rear wheel drive car i would also check the u-joints. From your description, it sounds either like a loose wheel or a wheel bearing, since the noise and vibration only occurs when you are turning. Hope this helps you, Rick
Apr 18, 2009 | 1984 Lincoln Town Car
Vibrations when drying
Unplug the dryer.
Take a putty knife and push the clips in between the front panel and the top lid.
Raise the top back, out of the way.
Inside the right and keft front sides of the front panel, remove the 2 screws.
Remove the wire connector to the front door.
Set the front panel aside.
Remove the screws from the blower wheel cover on the bottom left and check the blower wheel for free play on the motor shaft.
If free play is there, replace the blower wheel.
Reach underneath the drum and remove the belt from the motor pulley.
Lift the drum(it will take some force) by pulling the rear of the drum up.
Then pull it out.
The drum support is attached to the rear of the drum. The drum catch is mounted at the rear of the cabinet and is U shaped.
Replace both these parts.
Re-assemble and run your dryer.
Apr 05, 2009 | Frigidaire FDG546RE Dryer
Rear wheel
does the van shake or vibrate? does the van have tires on it ?start by switching the left rear with the right rear test drive and listen for soun if no sound then the tire has a bad steel belt replace tire if the sound is still present. jack up van and spin tire if no sound is heard replace wheel bearing and if there is still a sound look into brake drum for possible springs or clips that may have fallen into drum causing noise but i would say its more than likely the rear wheel bearing to change that u must buy a new bearing and follow instructions on replacing good
Jun 30, 2008 | 2000 Dodge Caravan
Whirlpool Duet GHW9150P Front Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
