I have an old G6-350 Gateway Computer running Win 98. It only has a tiny Power Supply, and when I plug it into any of the Moniters I have here, It says that the Moniter is too HD, I'm wondering if I could use a bigger Power Supply on it and see if that will solve the problem. The Power Supply on it right now is 90W if I'm reading it right.
    President:
  • 2,653 Answers
I'd say give it a shot. It's an oldie anyways so if it doesn't work, no biggie.
Posted on Mar 03, 2009
Not sure which plugs go where on the bestec atx300 power supply for gateway computer. remopved the old powere supply, but don't know which plug goes where on the new one.
I'll assume that your old PSU is also an ATX. First, the plug that has a few dozen wires arranged in a rectangle goes into the MB. Your PSU's ATX connector may be split into 2 parts: the AT portion and a square portion with 4 wires. Together, they make an ATX plug. You'll find some tiny plugs with 2-3 wires for your onboard fans. You might find a few slightly larger flat plugs with 4 wires for old floppy drives. The rest should be the regular MOLEX plugs and slim SATA power plugs for your drives.
Aug 15, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Old computer gateway gp6-400c i reinstalled win 98se now i have no audio
Go to Gateway Support website and type your serial number. All drivers for this model will be listed.
http://support.gateway.com/support/drivers/dlcenter.asp?cmpid=topnav
May 17, 2010 | Gateway GP PC Desktop
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
My fpd 1730 moniters brightness and contrast are terrible, and i cant get the controls to work
nonnie707, It is very possible that your monitor's internal or external (lay on floor) "switch-mode-power-supply" has a problem. Prove that your pc is working by connecting KNOWN GOOD monitor to your pc!!! If you are not electronics technician then you will need to question Gateway as to warranty service or possible swapout for a REFURBISHED unit if your unit is deemed as premature failure. May cost $ for swap. READ my FIXYA profile and that of other FIXYA TECH's (buddymc, budmrtn) for more options as to "what to do"!!! Remember, If very strange and weird things start to happen (occur) with "cold-cathode-fluorescent-lamp" backlit LCD display, the first place I would investigate would be the units "switch-mode-power-supply" Good luck with the repair. 12fixlouie
Feb 02, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
Driver for v220 logitech mouse os win 98
Hi
I'm afraid the USB mouses will not work on windows 98, please use the adapter so it fits into a ps2 port. (the old mouse plug) then of course you can check the logitechs website if they offer any drivers for windows 98 but its very unlikely.
Actually I looked myself and the oldest they offer is xp.
http://www.logitech.com/index.cfm/428/3295&hub=1&cl=us,en
so it would be a good time to buy a new computer, yours must be around 12 years old. considering that 5 year old machine is considered old, your 12year old machine is ancient.
Dec 26, 2009 | Logitech V220 Mouse
USB Memory stick
Sandisk usually sells memory sticks that are backward comaptible with win 98, but more than likely you will have to go to their website to find the driver because it will not be included. I have a 256 MB memory stick from sandisk that also has a driver for win98. I know this because I've used it on a win 98 machine. Once again, I had to go to the support page on the Sandisk website to find the driver.
As for the upgrade, you can probably upgrade to XP for $200 or less, without having to upgrade hardware.
Oct 27, 2008 | Gateway E-4200 Notebook
Computer wont power on
you should get the systemboard replaced and regarding the power button its a less expensive but replacing the systemboard needs to be replaced as two power supply cannot be bad.
Jun 09, 2008 | Gateway GT4022 PC Desktop
Gateway FPD1960 TFT works with laptop, not desktop
Elbtax,
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Mar 18, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Power supply
fan o. k
get the eq wit a bootable win. disc and run into the bios for a new set in xp
Oct 15, 2007 | Gateway (4000484) Motherboard
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
