Question about Roper RAK2751WWH Top Load Washer
I have a roper that spins but want drain
I have a roper top loader that spins but want drain
  • Roper Master
  • 3,361 Answers
Your drain pump is clogged.
Remove the cabinet, remove the pump and remove whatever is clogging the pump.
The pump is located in front of the drive motor.
Posted on Mar 03, 2009
Roper washer rax7245awo won't spin/aggitate
is this a top loader??there are clips on the edges of the top..they require use of a regular screw driver(flat blade) inserted between the top and sides..them it should pry up and tilt to the back..on hinges..
Feb 02, 2014 | Roper Washing Machines
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
Leaks when the washergoes into the spin cycle.
Could be crack on underhose or possible drum fault
Sep 30, 2009 | Roper RAS6233KQ Top Load Washer
Roper rtw4340sq0 top loader sicks in rinse mode.
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Jul 24, 2009 | Washing Machines
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Have a roper ras7133kq1 top loader. It will fill with water and will do nothing else. when i manually set it to spin it makes a squealing nose and the water just drains out.
go to www.repairclinic.com and enter your model number. the first part you see is what is wrong with your washer's spin. replace that and you'll be good. this is found underneath between the motor and the transmission.
Apr 03, 2009 | Roper RAS8445KQ Top Load Washer
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
I have a Roper brand top loader washer and it fills up but it won't drain or spin.
If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
Jan 30, 2009 | Roper RAK2751WWH Top Load Washer
Roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
Sep 16, 2008 | Roper RAX4232KQ Top Load Washer
Roper RAK2751WWH Top Load Washer Logo
163 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
