Question about Canon PowerShot SD600 Digital Camera
"Device is in use by another program" error message
Canon SD600 PowerShot Digital Camera
Windows XP Home Edition on a Dell Laptop
After connecting camera to USB port as indicated in the manual, I get an error message "Device is in use by another program" when I try to access the pictures (or the properties of the device from the Scanners and Cameras window). When I access the Properties from the Device Manager window, it says the device is working properly.
I have uninstalled the device; uninstalled all software associated with the device, uninstalled the USB ports. When Windows reboots it recognizes that USB ports are there; I connect the camera and turn it on and it still says Device is in use by another program.
  • Larry Lee
    Larry Lee May 11, 2010
    Have you tried using a card reader and Picasa3 (free software from Google? There are lots of inherent problems with going direct from camera to computer. Using a card reader TOTALLY eliminates the difficulties and costs only $15-20 for a cheap one (less when on sale!)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 09, 2012
3 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: battery fully charged. but canon powershot sd600
Your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
  • 28 Answers
SOURCE: my computer wont recognize my digital camera
Have you tried using Nikon software such as Transfer NX or View NX (available to download off the web for free from your Nikon Website)
This may help,if you are using "Generic" software this may be part of the problem.
See if this helps and let me know.
Ian561
Posted on Mar 29, 2010
I have a Canon IXUS 100IS and my Windows XP Home
Simple...get yourself a card reader and use it from now on.
Jul 08, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Trying to download my pictures from Canon Powershot A430 onto my new laptop Windows 7. Downloaded the disk and now trying without success to download my pictures onto the computer. Help??
Supported windows Operating system Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2 Canon PowerShot A430 has no update about the new driver software for windows 7 Try doing this direct transfer in your computer 1. Connect the camera to your computer using the supplied USB cable of your camera. 2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate. 3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow] 4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder. ** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another. ** Issue on the operating system compatibility.
Apr 14, 2010 | Canon PowerShot A430 Digital Camera
My computer will not recognize my camera...I
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=12956
If you go here it says that for XP it does not have a driver, it also does not have one for Vista.
It does, however, have drivers for Win 98, so I am assuming that this is an older product and may not be supported by XP. But if you poke around in here you may be able to find a solution, not knowing the age of both products, or the purchase date, thats the best I can recommend.
Hope this helps!!
Jim
Aug 06, 2009 | Canon PowerShot SD600 Digital Camera
I need to download pictures from Canon SD600 and lost printer cd
Connect the Camera to PC using the supplied USB cable, for windows XP and later versions the pc will identify the camera device and pop-up a window asking for "what to do next?"
Select copy pictures from camera from the displayed list.
Dec 17, 2008 | Canon PowerShot SD600 Digital Camera
Canon Powershot SD600 Connectivity/Recognition Problem
You probably have too many unused devices in your computer, reboot in safe mode, and delete unused device from system devices. Not enough space here for a longwinded howto, but plenty of info on how to do this on the web. gurantee it will fix it
Aug 16, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 - Problems downloading images - same as below
did you download the canon download app or are you using the installed pc generic camera download app? it will make a diference if the computer cannot reconsile which too use. let me know and we can go from there
Jul 04, 2007 | Canon PowerShot SD600 Digital Camera
Sd600 digital camera trouble downloading pics to computer
Hmmm... Yea sometimes the pc doesn't see the added gizmo your camera. In which case, I suggest when you connect camera to computer click on "my computer" and you should see your device listed there along with your C drive & so on. Click on the camera icon & viola, you can copy the images from there to your computer. Yea I had the same experience with PS too, well Elements in particular. And there is a setting (somewhere in Elements Browser window) to turn it off. Yea to simply download images - it doesn't require any software at all with XP. I use a card reader & rarely deal with using the camera cable to computer hook up. To use that device you'll remove the card from the camera & stick in the reader & its ALWAYS worked for me. Again you'll have to click on "my computer" to find the images there. Otherwise --- next step would be to try another usb cable.
Jun 24, 2007 | Canon PowerShot SD600 Digital Camera
Canon sd600 trouble downloading images to computer
Did you checked that your existing camera's drivers are supported the Win Xp OS ?
Canon PowerShot SD600 Digital Camera Logo
120 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
