Question about Hotpoint Ultima WF860 Front Load Washer
Keeps going on test cycle
Hotpoint ultima wd860 washer dryer will not come off test cycle
  • 1,294 Answers
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Posted on Mar 08, 2009
    New Friend:
When I do this 'd off' doesn't come up
Posted on Apr 07, 2013
Hotpoint Ultima WD860 Washer Dryer not rinsing properly. Leaves white residue on dark clothes.
quit using powered detergent .we quit many years ago as it does not dissolve properly in our hard water .no problems with liquid .
Oct 16, 2015 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 Ultima super silent led screen stopped displaying information
My hope is that it is still under warranty. But I assume it is not. I get a lot of parts and diagrams, as well as trouble shooting help from an excellent web source at Enter your model number and it will give suggestions to check for, as well as order your part. Used it many times.
Apr 04, 2014 | Hotpoint Ultima WF840 Front Load Washer /...
Ultima WD860 - dryer has been stuck with 1 minute left for about half an hour. Have turned it off but obviously my stuf is stuck inside.
Please disconnect your WD860 from the power supply. The door lock uses electrical power to stay closed. After you unplug the machine from electrical power, just wait a couple of minutes and the door lock will be released.
Aug 26, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint wd860 leaks water but cannot find where its copming from all hoses are fine
open door and caerfully check right round the door seal this is very common on these machines.if ok unplug mach remove lid and check the hose from soap dispencer and tub this sometimes splits .cheers
Jun 08, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Operating instructions for Hotpoint Ultima WD860 washer/ dryer please
Go to the following site for the info you need.
In the menu on the left, click on---Hotpoint user manuals.
In the search box on the right, enterr your model number in CAPITAL letters, and without any spaces, then download the instructioins to your hard drive or printer.
Feb 07, 2011 | Washing Machines
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
367 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
