Question about Panasonic CT-27SL15 27" TV
My Panasonic 32" TV does not come on when I press power button on remote or TV. Is this power supply? & if so how do I fix it?
Plz check fuse then check power suplay or h.output transister
Posted on Aug 29, 2009
Panasonic plasma panasonic th-p42x10a green led on but tv takes long time for picture to appear
check for swolon capacitor in power supply or try to go in service mode and reset tv by pressing vol_ on tv and press recall button continious from remote tv will go to service mode then press vol_ on tv and ok from remote hold ok untill tv reset then unplug and turn on again.
Mar 06, 2012 | Panasonic TH Televison & Video
Panasonic 32" GAOO just atarted doing this...Turn
The Panasonic Gaoo sets were top of the line in it's day, the problem you are describing is a vertical deflection issue caused by bad solder joints and a few parts. I recommend a tv technician to fix the set.
Jan 09, 2011 | Panasonic CT-34WX50 34" TV
My 32" plasma TV (ikon)
My 32" IKON Plasma TV not getting on. when press power button on remote LED on TV getting bling only
Kindly Help
Abdul Rasheed
Dec 27, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on...
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
Sep 12, 2009 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Tv stays on after hitting the power button and remote stops working
it prolly is turned off but the image is burned into the screen
May 25, 2009 | Panasonic PV-C2020 20 in. Combo
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
TV Won't Power Down; Change Channels; Change Volume; etc
sounds like maybe the remote contol is at fault.Do the front panel buttons work?
May 29, 2007 | Panasonic CT-32G9 32" TV
My New LCD TV just turns off
It is most likely a microprocessor issue or a power supply failure. It is easier to let them handle the repair since you have the warranty.
Mar 01, 2007 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Panasonic CT-27SL15 27" TV Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
