I have a two-speaker computer speaker system. The second speaker receives its signal from the first speaker's out/negative terminal. Each speaker has its own power supply. I think that each speaker takes one signal (left or right) if so, how can I eliminate the second speaker (while still maintaining stereo (left and right signals) sound on the one?
    Problem Solver:
  • 8 Answers
Well if it's any thing i have seen male end ones small . speakers can take batteries or plug in . hey send me a picture i'll help you out Ricgen09@aol.com.
Posted on Mar 04, 2009
I have an 2002 Nissan altima and DA display on the radio is working but no sound
Hi candy Love , I love that name ! What Altima ? S ,SE or SL
AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
 through 15A fuse [No. 31, located in the fuse and fusible link box]
 to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
 through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
 to terminals + and - of front door speaker LH and RH
 to terminals + and - of rear door speaker LH and RH
 to terminals + and - of tweeter LH and RH.
BOSE® SYSTEM
 to audio unit terminal 6, and
 to Bose speaker amp. terminal 1.
Ground is also supplied
 to speaker amp. terminal 17
 through body ground B117.
 to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
 through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
 to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
Feb 01, 2015 | 2002 Nissan Altima
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
What are the color connector labels
Red is positive, black is negative. Your receiver, or amp, will have similar color coded terminals. Just make sure you run a wire from the red terminal on your receiver to the red terminal on your speaker. Same thing for the black.
Oct 22, 2013 | KEF Fivetwo Series MODEL11SL Floor...
My fisher-RS939 audio stopping getting out through the speakers and do I get it out if the system is in protect mode
Normally when receiver keeps entering protection mode it means wires are crossed or touching somehwere. Double check all speaker wire connections at the receiver and speakers. More than likey the positive and negative wires are touching at one of the terminals.
Jun 19, 2011 | Fisher RS939
What wires are for what on my kd-g200
The cables for you In-Car stereo are as follows:
Black - Earth to to the chassis.
Yellow - Live that should be connected directly to the car battery and not the igniton.
Red - To an accessory terminal in the fuse block.
Blue / White stripe - To remote antenna (if fitted)
White / Black stripe - Front left speaker (negative terminal)
White - Front left speaker (positive terminal)
Grey / Black stripe - Front right speaker (negative terminal)
Grey - Front right speaker (positive terminal)
Green / Black stripe - Rear left speaker (negative terminal)
Green - Rear left speaker (positive terminal)
Purple / Black stripe - Rear right speaker (negative terminal)
Purple = Rear right speaker (positive terminal)
That covers all off the cables that you should have with the car stereo.
Apr 11, 2010 | JVC KD-G200 CD Player
I have to connect 11 speakers in a restaurant to a 2 zone amplifier that is 500 watts per Chanel. How do I choose the power of the speakers and Which way do I wire them --- in parallel?
what size speakers and what watts, how many channels on the amp, you could do it in either way
There are two ways to wire electrical components. In parallel or in series. Both are important to understand, especially when properly hooking up speakers to amplifiers.
Parallel wiring is connecting components to a source so that they share the same voltage. To put that in a useful way, it would be connecting all of the speaker positive terminals to the positive terminal of the amplifier and connecting all of the speaker negative terminals to the negative terminal of the amplifier.
Series wiring is connecting components to a source so that they share the same current. To put that in a useful way, it would be connecting the amplifier's positive terminal to the positive terminal of the first speaker and then connecting the negative terminal of the first speaker to the positive terminal of the second speaker and so on. The final speaker in the chain will have it's negative terminal connected to the negative terminal of the amplifier. Hope it Works
Oct 18, 2008 | Audio Players & Recorders
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Wires came out of the plug
From Pioneer Electronics Support Website Yellow - To terminal always supplied with power regardless of ignition switch position. Red - To electric terminal controlled by ignition switch (12 V DC) ON/OFF. Black (ground) - To vehicle (metal) body Blue/white - To system control terminal of the power amp or Auto-antenna relay control terminal White - front speaker left + (positive) White/black - front speaker left - (negative) Grey - front speaker right + (positive) Grey/Black - front speaker right - (negative) Green - rear speaker left + (positive) Green/Black - rear speaker left - (negative) Violet - rear speaker right + (positive) Violet/black - rear speaker right - (negative) Best of Luck.
Sep 09, 2007 | Pioneer DEH-P3800MP CD Player
70 people viewed this question
 Grubhead
Grubhead
