Home | Xerox | WorkCentre M15i Laser Printer | Try to use scanner err...
Xerox WorkCentre M15i Laser Printer
Problem for Xerox WorkCentre M15i Laser Printer
Try to use scanner error says failed to connect.
By fnperez on Mar 03, 2009
Try to use scanner error says failed to connect. I have deleted and added software etc. issue does not go away.
Solution #1
posted on Oct 23, 2009
Not Rated)
gilbertgonz8
Rank: Guru  Xerox Computer Hardware  Expert
Rating: 93%, 25 votes
The problem may be in the scanner motor or the main board.
If you are not able to get it repaired to place a service call with Xerox.
The correct parts need to be installed for this model.
Was this helpful?
Yes
No
Popular Solutions for Xerox WorkCentre M15i Laser
Questions and Unsolved Problems for Xerox WorkCentre M15i Laser
Do you recommend Xerox WorkCentre M15i Laser Printer?
Answer
Answer
I just replaced my color and black ink cartridges and it's showing they are both full but when it... (More)
Answer
i need a meter reading for a konica magicolor 2400W. How do I do this?
Answer
I enter CREATE PDF FROM SCANNER. Select XEROX M15WORKSERIES. ERROR MESSAGE : CANNOT BE SET TO THIS... (More)
Answer
I have problem in my printer it is not accessing the order threw the my pc
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xerox WorkCentre M15i Laser...:
Top Printer Experts
Rank: Guru Guru
Solutions: 411
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
