Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Garage door won't close
The door will open when you push the wall button but when you try to close it - it reverses, reopens and the light flashes 4 times. There is no obstruction (leaves, cob web, etc), the sensors are working and properly aligned and the door looks to be manually closing well. It is a GarageMaster 1/3 hp, which I understand is made by Chamberlain, and came with the house I bought so I don't have a manual and is probably about 12 years old. I appreciate any responses....Thanks Dee
  • 74 Answers
SAME AS ABOVE... AND IF ISNT WORKING TRY TO INCREASE THE DOWN FORCE OF THE GARAGE OPENER 1/4 TURN UNTIL CAN CLOSE IT... AND IF ISNT WORKING STILL MAYBE UR TORSION SPRING OF UR GARAGE DOOR HAS TOO MANY TURNS.. CALL A TECHNICIAN!
Posted on Mar 09, 2009
  • 5,425 Answers
Check if there is a shadow being cast onto one of the sensors as the door closes. We've had the rope for manually closing the door cast a shadow in full sun and trigger the "something crossed the beam" safety reverse. (Our temporary solution was to cast a shadow that remained constant from outside the door.)
Similarly check if there are any weeds or grass that are being blown or bent into the opening as the door closes. If there are plants in or near the doorway, trim them or use an herbicide to kill them and then trim the top growth after the plant dies.
Posted on Mar 03, 2009
Garage door closes most of the way, then blinks and reopens
You can adjust the downward sensitivity by turning an adjustment on the opener
Nov 28, 2013 | Home Security
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door will close with the wall pad but when the remove or key pad is used the door reopens. How is this fixed?
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Mar 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have Garage Door Opener from Sears. Wall push button & the the remote from my car open the door OK , but it does not close the door from my car (which is programmed) Wall push button close the door...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 53918 - 3/4 hp, belt drive garage door opener. Wall unit says safety sensors misaligned. Replaced them as suggested by manual, no fix. Does not appear to be any power from where you plug...
The main light flashing 10 times is the sign of a door sensor problem. Check to see if the small light on each sensors is lit and not flickering. If you cannot get both lights to come on your sensors or the wiring to them is bad.
Sep 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
After a lightning storm, my LIftmaster Formula 1 garage door opener will not close without continually holding down the garage door button on the wall. If you push the button once and then let go it will...
If when the door reverses the main light flashes 10 times you have a problem with the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. They must be pointed at one another for both lights to be on. If you cannot get the lights to come on you have a bad logic board.
Jun 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
What do 4 flashing lights mean on craftsman door
4 FLASHES
Safety reversing sensors slightly misaligned (dim or flashing LED).
Dec 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
562 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
