Question about Sharp AR-235 Copier
F9-00 (Print Function) Error Code on Sharp AR-287
The machine contains necessary hardware to network print. Any advice on how to proceed?
  • Anonymous Mar 12, 2009
    Network connection ok probably bad card...thanks.
  • 29 Answers
This copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Posted on Mar 09, 2009
SHARP 287 CODE F-2-31 ALSO TO GET RIDOFF THE BYPASS COCE MANAGMENT SET UP
Posted on Apr 03, 2009
I have sharp ar-287 error ha-04. How to fix?
this sounds like you have a jam in your fuser unit.To remove this jam open the door at the left hand side,you should see a green lever to the back end lift up and take paper out,after doing this you then have to reset this error code.To enter service mode press P interupt C interupt key in 14 press start key then press CA.Photocopier should reboot if this does work then you need to get your service engineer out
Sep 15, 2009 | Sharp AR-507 Copier
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
Sharp ar-287 network password reset
Try deleting the printer in control panel. delete the drivers and reinstall software and drivers.
Jun 13, 2009 | Sharp AR-235 Copier
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
Sharp AR-287 fault code E7-11
Hello sir; The error code means there have communication problem between main board and sub board,operation board, icu board or print, my suggestion, go buy a new copier, it not worthy to repair !
Feb 27, 2009 | Sharp AR-235 Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
Sharp AR-235 Copier Logo
1,575 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
