Question about Boston Acoustics BA735 Computer Speakers
I have a set of self-powered computer speakers. They are in-line, meaning that that the other speaker gets its signal from the first. I am pretty sure that the speakers still split left and right signals. How can I (if it is possible) eliminate the second speaker (while still keeping stereo sound w/ both left and right signals? Again, the amplifier board only has one out wire. The second speaker gets its signal from the negative terminal on the first speaker. Thanks!
    Problem Solver:
  • 8 Answers
Unless you put a smaller speaker in the right speaker try it but you might f@#k up the speakers
Posted on Mar 04, 2009
No sound at all, but power on. Should I replace the phone jack?
Hi Hermann ,
This is a typical issue with Logitech speakers . You need to bring them back to the the dealer and get an exchange set for free replacement onder warranty . If the warranty has expired , you will need to solve the problem by testing the cables or the printcircuit inside the sub , BUT first connect your head phones or another speakers set to the correct output of your computer's soundcard to verify if the issue actually commes from the speakers . If the test is negative , the issue is to be found in the soundcard and you will need to replace it .
Best regards .
May 10, 2014 | Logitech X-230 Computer Speakers
My Dell AX510 Soundbar Speaker isn't working, although the blue light is on, indicating it has power. I'm using a Dell monitor that is set up primarily for Playstation usage.
Ensure that the sound is actually supposed to be coming through the speakers. Just because the power is on doesn't mean that audio information is actually on it's way to the actual speakers. Maybe the television volume is low or muted, maybe the output volume is being routed somewhere else, or maybe the soundbar is broken. You should investigate and follow the signal to find the problem.
Sep 29, 2013 | Dell Ax510 Ax510pa Soundbar Sound Bar...
Speakers have no sound
Please check the below mentioned things :
Verify the AC power cord is plugged into the wall outlet. Turn the VOLUME knob on the right speaker until you hear a click sound. An LED will light next to the knob when the power is ON. Turn the VOLUME knob clockwise to raise the volume. Check volume level on the computer sound card or alternate audio source device, and set at mid-level. Check plug connections on the audio source. Make sure the signal cables are inserted firmly into the correct jacks. Make sure the 3.5mm stereo cable is connected and fully inserted into the "line-out," "audio-out," or the headphone jack of the audio source. Test the speakers on another audio device. Remove the 3.5mm stereo cable from the audio source device and connect it to "line-out," "audio-out," or the headphone jack of another audio source.
And if in in case u r unable to get it working ..
Replace the speakers ..
Jan 24, 2011 | Altec Lansing VS2120 Computer Speakers
How to set up
these speakers are easy to setup. The two speakers are already connected to each other, and the out cable comes from the speaker with the power and volume. The subwoofer and power also connects to that speaker. you would liked to have had the second speaker have the ability to totally disconnect from the main speaker, and you would also have liked to have had a headphone jack built into one of the speakers. Besides that, these are very easy to use, press power, turn the volume to a desired level, pretty straightforward. thanxs
Aug 09, 2010 | Cyber Acoustics Accent S-3022 Computer...
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
Tivoli Stereo Speaker
Any speaker has the potential to be used as a computer speaker. The problem you will run into is what will be used to power the speaker. Typical computer sound connections do not put out a strong enough signal to power a full sized speaker on their own. If you hooked the computer to an amplifier and then to a speaker it would work fine. If you do this, I recommend using the line out connection on the computer instead of the headphone connection.
Jul 20, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
YST-MSW10 quits after about 15 minutes
sounds like a fuse is getting overheated and tripped or to loud, check your volume settings again.
Jul 29, 2007 | Yamaha YST-MSW10 Computer Speakers
Boston Acpustics BA745
you cannot plug the phono jack directly into the motherboard, there needs to be another piece that you can add, it has a yellow speaker sticker that you install into the computer, onto the motherboard. it is not an add-on card, but an accessory you can buy. this is because the speakers are self-powered, meaning that they need power from the motherboard instead of an AC adapter
Nov 17, 2006 | Boston Acoustics BA745 Computer Speakers
Boston Acoustics BA735 Computer Speakers Logo
54 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
John Trigg
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
