Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
My gold quite 3 rattles when draining. The
My gold quite 3 rattles when draining. The spin bar on bottom
is loose and want to tighten it
to see if that fixes it.
How do you tighten it
  • 38 Answers
Turn the plastic center screw counter clockwise. The bottom spray bar is supposed to be loose so it will rotate under water pressure. Rattling maybe coming from diswasher/cabinet contact, or debris caught in the main pump or drain pump, or the food disposer.
Posted on Mar 05, 2009
Whirlpool spin cycle rattling
Well, it just might be. :-) More than likely you have something in your machine basket that is loose. Probably a coin or something from clothes previously dried or washed in the machine. This is quite common, especially for folks who carry coins or loose objects in their pockets. Remove whatever is loose in the basket and you will have solved your problem.
Jan 03, 2015 | Whirlpool Washing Machines
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
How many ft. lbs to tighten handle bar bolts on the risers of 2004 FHLRCI ?
I've never seen a specific torque value listed for a riser bolt, neither the large bolt on the bottom or the smaller bolts at the top. Simply tighten them to within reason, not too loose but don't strip the threads either. The large lower bolt or nut should be quite tight. The smaller 3/8" bolts at the top should be just tight enough to prevent the handlebars from slipping. I'd use Loctite 242 medium blue on all the bolts.
Good Luck
steve
May 07, 2011 | 2004 Harley Davidson FLHRS - FLHRSI Road...
Hi,I am working on a 1991 VT600c,I have changed the fork oil following the instuctions on the manual.I tried to make the bottom drain bolt loose so i could drain the oil out.This bolt broke loose but does...
Put the fork back together. The spring tension from putting the fork top/cap on is what allows you to loosen and tighten the socket bolt on the bottom. It is easiest to work on the fork with the tube clamped into the upper and lower triple clamp of the motorcycle. When you first get access to the socket bolt on the bottom, you take it out. Do not loose the sealing washer. if you are not ready to drain the fork , you put it back in loosely. When you are ready to fill the fork, you put the socket bolt and sealing washer in and snug them up just enough to keep the fork oil from leaking out. Do not over fill your fork it will damage the tubes.. After the fork top is back on and screwed down , you tighten the socket bolt on the bottom and continue reassembling the bike.
Sep 23, 2010 | 1991 Honda VT 600 C Shadow
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
How to replace chainpoulan pro 18"
First lay the new chain out with the cutter teeth facing forward on top. You should wear gloves because it takes very little to inflict a deep cut with these chains.
Take the tool that came with your saw and loosen the two nuts (don't take them off yet)that hold the sideplate on over the chain. Leave the saw setting on its bottom.
When the nuts are loose take the screwdriver end of your wrench (or a screwdriver) and loosen the chain quite a bit. Wearing the gloves, make sure when you pull it forward it moves very loose.
Now take the two sidecover nuts all the way off. You'll see how the chain goes arpound the sproket. Push the bar back toward the sproket until it is loose enough to remove the chain.
The bar will come off too, and it is important to note the small nub that goes in the tensioning hole on the bar near the bottom of the saw, fairly close to the sproket. Keep the chain straight; I hang mine on nails driven into the wall in my shop. You can get them kinked up so that they seem they'll never straighten out.
Take this time to clean all behind the sidecover itself, and the entire enclosed area. There will be sawdust, twigs, etc. I blow mine off with compressed air, but protect your eyes. Take something, toothpick, Qtip, or the like and clean the groove all the way around the bar, including the oil holes near the rear.
You should now be ready to insert the new chain, putting the bar with the slot lined up with the sidecover bolts, and gently get the chain on the sproket. This may take a couple tries before you get it right. When it is on (you'll see you have to hold the bar up or it will tip too much) hold the bar in place with the tightener in the hole, and slip the side cover back on. Tighten the nuts just enough to hold the bar in place, then tighten the chain tension screw, while holding the bar. Tighten the side nuts more, until the bar is held in place.
When it is just tight enough to hold the bar but not prevent the bar from moving forward when you tighten it, tighten until you can still move the chain, but there is no visible slack in the chain. You should be able to grab the chain at the bottom and with moderate force pull it away from the bar about a half inch.
I like to pour a little oil on a new chain so it has plenty of lube. The chain will stretch because it is new. Run the saw at about 1/3 throttle for a minute, holding the end close to something to make sure the chain is throwing off a fine thread of oil. Then run it at 1/2 speed about another minute. Rev it a few times, make a practice cut or two, and it should by now need another slight tightening.
Sirwriter
Jun 07, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Whirlpool dishwasher spinny thing is rattling
Hi, I suggest u to check these :
  1. Check the spray arm for damage and obstructions
  2. Check the inlet filter screens
  3. Test the water inlet valve
  4. Check the motor and mounts
  5. Check the fan motor and blade
  6. Check the drain for obstructions
Apr 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kitchen sink drain loose
You can probably tighten it from the bottom. But first, get a little plumber putty from the hardware store and put it around the seal from the topside of the sink. As you tighten it down, it will squeeze out a bit, but that is okay. Good luck!
Mar 25, 2009 | Plumbing
HELLO, WSL100D0WW IS MAKING NOISE ON DRAIN/SPIN CYCLE.
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
May 17, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
160 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
