Question about HP Audio Players & Recorders
Speakers not playing clear
Bought model MMS231HP from a pawn shop but when plugged to my computer the sound that comes out sounds like a lot of static
    Problem Solver:
  • 8 Answers
Bad 35mm end. you can change in if you like with another one. should work
Posted on Mar 04, 2009
SP OFF mode?
if you turned it on without speakers hooked to it you may have blown the speaker output amps or if the end of the amp remote wire touched a ground you may have burned a trace on the board did you here it play at the pawn shop? or did it just light up? sometimes the people at the pawn shop think if the unit lights up it is working and sometimes they check them is just hook power to them without speakers if so this can blow the speaker output I would take it back to the pawn shop
Jan 29, 2014 | Kenwood KDC-MP235 CD Player
I bought a used pyramat 440 chair. the right speaker hums a lot and no clear sound is coming out. there is static. the peakers have been dented. where can i buy new speakers? or is there anything else i...
If they are dented they are most likely ruined. Pull the speaker out and you will be able to find a match for them online based on the part numbers.
Jan 26, 2013 | Audio Players & Recorders
My woofer and speaker make a lot of static and one speaker does't have any sound, it seems that when I move the blue connection the one from the speaker to the woofer the woofer gets louder and so does...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 29, 2011 | Boston Acoustics BA745 Computer Speakers
I have bought two intex multimedia speakers 2.1........but one of these does not sound clearly
try swapping the speakers around if the problem still persists either the speaker is faulty or
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Apr 02, 2011 | Computers & Internet
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Flat screen monitor
First, make sure that you have all the necessary cables connected, then make sure that they are all connected properly and tightly. Also, make sure that your computer is set to output to the correct output. If that doesn't work, then the speakers are probably broken. That's the exact reason why you don't buy stuff from pawn shops. Cheap, but crappy.
Mar 24, 2008 | Acer AL1917W LCD Monitor
Audio static
Hi: An alignment of the video if and or the audio circuits may be necessary in a repair shop.
How old is this set?
Al
Mar 17, 2008 | Televison & Video
Can't get my durabrand uc-280 computer spreakers to work
Returned the durabrand uc-280 to Walmart! Plugged the existing speaker into the correct hole in my new sound card. Problem solved!
Feb 16, 2008 | Audio Players & Recorders
Sound problems
are you sure you have plugged in the speakers properly? maybe u inserted the cable in the wrong port or u just didnt insert the cable property. A loose connection can cause static and obviously it wont play anything. Please check.
Dec 24, 2007 | Harman Kardon HK19.5 Computer Speakers
Cant select A or B speakers
Did  you make sure its on digital 1
Sep 22, 2007 | Onkyo TX-DS747
90 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
