Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Why might it be that my remote for the fan/light Hampton Bay sometimes is able to work and other times not? When it doesn't work, the red light on the controller stays on. Then, it might later go off and everything works again for a while. Then...
  • 2 more comments
  • espian Mar 03, 2009
    no, that's not it, as I've replaced the batteries a few times to check.  Thanks, though
    I know it is not the battery
    Maybe I'm posting to the wrong section? I just realized this is for universal remote units. Mine came with the fan.
    It says FAN-HD  Can't find any other id on it or in it.  Thanks
  • 423 Answers
It's not the batteries in the remote. The light showing on the controller tells you that the remote is communicating with the controller. I would bet your controller has a problem. Here are a few things to check.
First, try this as it doesn't cost any money!
Disconnect the power to the controller. Wait a minute and reconnect power. Does this fix it?
If not, then my first thought is the relay on the reciever. It may be going bad (suggesting why it works sometimes and sometimes not). If it's a bad relay in the controller, simply order a replacement.
You can also check the controller to make sure your dip switches are in the correct position. Your dip switch controls the signal input. (in the case of multiple fans, you wouldn't want them all coming on at the same time). Make sure your dips are set to match your remote. This just takes trial and error if you don't have the manual. (I believe there are 16 permutations for the dips.)
Sight unseen, it's probably a relay going out on the controller, or some other part. Either way, best bet is to replace the controller.
Thanks for coming to FixYa.
Rob
Posted on Mar 03, 2009
  • 523 Answers
Reprogram the Remote or after you see the red color you should hit back tv, in order the green color to come back, if you cannot you have to reprogram it with the tv code. if all this not working it seems the remote control falled down so the connection inside becomes lose.So you have to change it.
Best Regards
    Sergeant:
  • 250 Answers
If you take the fan down and remove the guard exposing the guts (wires) you can rewire the unit to bypass the remote sensor unit. Replace the switch on the wall with a ceiling fandimmer switch. This way speed can still be controlled. If the fan has lights you will have to wire them in with the fan, so they both come on when you hit the switch.
  • 54 Answers
If a light stay on in your remote could be some key stays pressed or there is a false contact inside your remote.
Good Luck!!!
    Brigadier General:
  • 8,619 Answers
Hi!
Try resetting th remote and then re-program it again.
  • Rylee Smith
    Rylee Smith Mar 03, 2009
    Please tell me the model no. of your fan and/or remote.
  • Rylee Smith
    You need to check the dip switches(IC's inside the remote and also inside the fan assembly near the either on top of the motor, or inside the switch housing or ceiling canopy. T
    hese switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and try a different setting. The fan and remote should have same settings, 16 settings are possible---
    0000
    0001
    0010
    0100
    0110
    0101
    0011
    0111
    1111
    1110
    1101
    1011
    1001
    1010
    1100
    1000
    The problem can also happen if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
    Please ask for clarifications.
    Thanks
    Rylee
    Sergeant:
    Novelist:
  • 277 Answers
The battery of the remote needs to be checked or may be replaced.
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
Trying to rewire a hampton bay light fan. I have
Try switching the red and white wires
But it should be working if the light is.
Make sure all the wires to the remote are connected good. You may just have defective remote.
Nov 29, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Aug 16, 2009 | Hunter 28156 Cote 54' d'Azur® Ceiling Fan
Fan remote doesnt work
you eighter A clean the red eye or B get the code or C get a new remote!
May 11, 2009 | Hampton Bay 52 In.Carriage House II in...
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Jan 25, 2009 | Universal Remote Control Hampton Bay...
Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
Remote control fan hampton bay
Just insalled a hamptonbay fan and everything works except the dimmer. Light comes on on wall switch but remote won't dimm lights
Apr 04, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
77 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
