Question about Desa International White Wireless Plug In Door Chime
I have two door chimes with the same frequemcy, but different codes. I need to place the chimes in different rooms as I am hard of hearing. How do I match both codes so that they ring at the same time when the bell-push is activated?
You need to change the pin configuration in both the remote buttons to match each other, (as well as the bell unit) just make sure they match on both bell units. Also, since one works just use that configuration and change the button pin configuration that does not work to the button that does on the other button unit.
Posted on Mar 14, 2009
What is the difference between A23 and A23S 12v batteries?
batteries come in different configuration as to where the positive and negative poles are placed on a battery
the difference between a23 and a23 s could be which sides of the battery top the terminals are configured
it will not matter if you are just using it for power for door chimes
Oct 20, 2015 | Cars & Trucks
When I drive my 07 Chevy Equinox I hear the door chime sound. I even hear it when I remove the key from the ignition. Do you know why?
The place to start for this is at the door switch itself. You will notice a small button or lever on the inside of the door. Either on the hinged side of the door or the closing side of the door. While it is chiming, open one door, and try manually pressing that switch. Move it around and press it harder to see if you can get it to stop. If you can then you have found your problem and replace that contact closure. The other issue is sometimes in the ignition tumbler itself. If that is the case then the tumbler needs to be replaced. That one is a bit trickier to get to but doable.
Jan 30, 2015 | 2007 Chevrolet Chevrolet Equinox LS
Setting the codes for the door chime
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Aug 26, 2014 | Desa International White Wireless Plug In...
Reading on door OF
Teresa, The fridge is in a retailers demo mode and here is what you do to reset it to normal operation:
Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
  • At the top of the door frame: Simultaneously press and hold the "Power Freeze" and "Freezer" buttons until you hear a distinctively different chime sound and the temperatures for the fridge and freezer are both displayed.
  • Note: If the temperature is displayed, but then "OF OF" reappears a few seconds later, Cooling Off mode was not disabled. Repeat the actions above, and be sure to press and hold the buttons at the exact same time until the distinctive chime sound is heard and both temperatures are displayed.
Apr 11, 2014 | Samsung RF265AA Bottom Freezer French Door...
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
Wd-1140 door bell
set the different switch for door chime.good luck!
Jun 24, 2012 | Desa International White Wireless Plug In...
Open door chimes and keys left in in car chimes plus left on chimes not working question what operates chimes door lock ?
Door left open chime is operated by your interior light switch. It is located in a few places on different vehicles. Often in the door jam at the front or low down on the pillar at the rear of the door. You will notice a little black rubber boot and when you push it it goes in and out. That is your interior light switch.
Feb 04, 2011 | 2000 Volkswagen Golf
I have a ge wireless doorbell and I need to change the codes. there are 3 dip switch setting and 4 removable switches
The 3 dip switches set the different chime sounds. The 4 jumpers set the code....you will need to change the jumpers on the back of the receiver to match as well
Nov 26, 2009 | Desa International White Wireless Plug In...
What's the code so the doors don't lock automaticly....what a pain this feature is.
page 10 of the book for the durango
1. Close all of the doors.
2. Place the key in the ignition and cycle the key from the OFF position to the ON position for a total of four times ending in the ON position, do not start the engine.
3. Press the drivers side power door lock switch to lock the doors within 30 seconds.
4. You will hear a single chime when the programming is completed.
5. To activate the feature again, repeat the above steps.
...And from pages 12-13:
To unlock the doors and liftgate: Press and release the UNLOCK button on the key fob once to unlock the driver's door, or twice to unlock all doors and liftgate. The illuminated entry system will also come on. The system may be programmed to unlock all the doors, on the first press, using the following procedure:
1. Close all the doors.
2. Place the key in the ignition and turn the key between the OFF and ON position consecutively for a total of four times ending in the ON position (do not start the engine).
3. Press the driver's side power door lock switch to unlock the doors and within 30 seconds to lock the doors.
4. You will hear a single chime when programming is completed.
Aug 21, 2009 | 1999 Dodge Durango
Desa International White Wireless Plug In Door Chime Logo
506 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
