Question about Canon CanoScan LiDE 70 Flatbed Scanner
Scanner making annoying drag lines
When I scan images they come up with big drag lines that are lighter/darker than the original image going all the way down (I can clone stamp them out in photoshop, but it is so annoying and time consuming. I hope this doesn't mean that I have to get a new scanner.). any ideas of why this is happening or how to fix the problem?
    Scholar:
  • 157 Answers
Check first before the software problem before to proceed hardware problem...first thing, you can check to uninstall the driver of that scanner.or else try in another pc if it is working good..if not,it means theres a problem in the hardware...
Posted on Mar 03, 2009
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
How can i scan a photo?
You can scan photos by
1 Open the top cover, and then load an original document facedown on the scanner glass.
2 Close the top cover to avoid dark edges on the scanned image.
3 Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4 From the printer control panel, press "scan" button.
5 If you are using a Macintosh operating system, click on the document or image preview and drag to select the
part that you want to scan, and then click Scan from the Scan dialog on the computer screen.
6 If you want to save the scanned image, then from the software application, click File Save As.
7 Enter the file name, format, and location where you want the scanned image saved.
8 Click Save.
done..
May 23, 2010 | Lexmark X2670 All-In-One Printer
How do you scan a picture into the computer with a lexmark P6250?
SORRY, I COULD DO ALL, SAID TOO BIG, Using a computer 1. Make sure your All-In-One is connected to a computer.
2. Load your document face down on the scanner glass. For help, see Loading your document on the scanner glass.
Open the Lexmark Imaging Studio. For help, see Using the Lexmark Imaging Studio
4. Click the Scan button.
The All-In-One Center appears with the Scanning & Copying tab expanded
5. Click Preview Now in the upper right corner of the All-In-One Center.
An image of the scanned item appears in the preview section.
6. Click and drag the dotted line box to select a specific area of the preview image to scan.
7. Click Display Advanced Scan Settings to review and change the scan settings. Click OK.
here is the web site where the info was. If you want to see better images just click on link below. good luck :0)
MORE LOOK AT WEB SAYS TOO LONG
http://www.lexmark.com/publications/
pdfs/2007/6200/winug/en/frameset.html
Nov 19, 2009 | Lexmark P6250 All-In-One InkJet Photo...
HP Laserjet 4345MFP scan to folder is too light.
make sure that you close the cover of the scanner so the original color of the image will apear on it.if you are looking the image on your computer.if the copy when you print will is light, try to change the resolution into picture quality.
Nov 15, 2009 | Office Equipment & Supplies
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
All the slides scanned are darker than the original
The problem is internal see this website for cleaning an Hp scanner but your problem is similar http://www.willshak.com/scanner/
Apr 19, 2009 | ACI Pacific Image Prime Film PF3650 Pro...
My scanning files are to big
Since there's not much information, I'm going to have to make a lot of assumptions with this solution.
The basic issue you have is not the scanning, it's the scaling after the scanning. Since you do not indicate what software you are using to scan the image, I can't be certain without knowing what you're using, but most of these scanning packages allow you to 'resize' or 'scale' the image. How much to scale depends on how large the original is, and how small you need the final version, so some experimentation may be in order. As an example, with my scanner, I typically resize to about 50% of the original.
If you don't have that option, most graphics programs allow this fairly easily (you simply save, then open the scanned image in the image editor and perform the scaling there). Or, some programs even let you resize without opening the file, such as Microsoft's free Image Resizer tool (http://download.microsoft.com/download/whistler/Install/2/WXP/EN-US/ImageResizerPowertoySetup.exe) which allows resizing by right clicking on the file name.
Jan 26, 2009 | HP Scanjet 5590 Flatbed Scanner
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Streaks in image scanned by Canon DR-2580C Path-Through
The staples cannot reach the sensors. They could have scratched the glass above the sensors. Clean the glass with IsoPropyl alcohol. Try scanning a few images to find if the scratch marks are on the same place on all images. Once confirmed that the glass is scratched, you can change the glass. You need a technical expertise to change or call service staff.
May 29, 2008 | Canon DR-2580C Path-Through Scanner
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
102 people viewed this question
old marine
old marine
