Question about Starbucks Barista Utopia
Waters not hot while making a shoot
I turn the machine on wait for the green light and make a shoot however the shoot is not hot its only luke warm, the steamer works fine and the if I run the machine with out the thing that holds the espresso it seems like the waters kind of warm.
  • 14 Answers
If the READY light is turning ON and the water is only luke warm, then it sounds like a temperature sensor problem. The sensor might be affected by scale, or it might be damaged or out of tolerance. Try to get a reading of the water temperature as it is, and then descale your machine thoroughly and see if the temperature gets hotter. If it does, then scale is probably the problem. If it doesn't then you will need to get the machine checked by someone who knows about espresso machines. If you can't find a repair shop, ask your local Starbucks who does the repair and maintenance of their machines and take your machine to them.
Posted on Jun 29, 2009
  • 2,039 Answers
Our due for a good clean up and descaling with expresso descaller put descalling agent in the water tank turn the steamer on for 20 second turn it off let it seat for 15 minute repeat untill empty and rin se very good hope it a fixya for you and me thanks pierre
Posted on Mar 04, 2009
A.o. smith powerhouse powershot nat gas hot water heater 40000 btu the vent hasnt stopped running for 3 days and the water is luke warm at best
If the vent has been running for 3 days, is there fire in the hole? I suspect there is a lot more to this story. If there is fire in the hole, turn off gas and call someone before you get killed. Seriously.
Apr 02, 2014 | Water Heaters
I have abosch 1600 ps aquastar 4.3 gpm indoor when i turn hot water on it all fires up but no hot water comes out only luke warm water why
Water heater is heating water but only luke warm water arrives at faucet.
Open TP valve and confirm that hot water is available.
If water at TP valve is hot, then problem might be plumbing-related, for example crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2011 | Bosch 1600PS NG Aquastar 4.3 GPM Indoor...
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
The first problem we noticed is the coffee is not as hot as it used to be, but it was still strong enough. Now the unit perks for about 10 min for a full pot, the light comes on....but the coffe is weak...
Hi, The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix. Thanks and please ask if you need more help. Ron For the part go to repairshack.com
Aug 17, 2010 | Faberware 10-22 Cup Coffee Urn
Hot water for only 5 to tn minutes then have to wait.
You have an element gone of your hot water is running out quick and having to wait for it to heat up again. Best thing to do is to go ahead and replace both of them.
If you replace just one it will work the old one till it causes it to go. Most of the time if the top element is good you will get a blast of hot water and then it will get cold. With the bottom element only working it will be luke warm water for a while then go cold.
If you need a guide how to replace them got to the link below for further information. It will guide you through trouble shooting your heater.
http://www.water-heater-repair-guide.com/waterheaterelementreplacement.html
Jun 24, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Luke warm water on sanitize cycle, why?
remove lower kick panel and check wire connections to heater. 2 wires go to heater terminals and a harness connector goes to temp sensor in middle of heat terminals. may be green ground connection on another term. use multimeter and check resistence on heater. during cycle heater will take time to heat.
Mar 16, 2009 | GE WBVH6240F Front Load Washer
Coffee Makers & Espresso Machines Logo
163 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
rob j
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
