Question about Akai DVDRW120 DVD Recorder
I have a Akai DVDrw125. I've never been able to connect it between the cable signal in and the TV. It has S-Video in and S-Video out. The manual is worthless. I shouldn't have to switch the S-video cable from the receiver to the DVDrw125 to watch a video but that's what in fact I have to do. I even went to Akai looking for more information and the search on there website doesn't even pull up anything with ''dvdrw125''
  • Alan Moreno Aug 23, 2013
    Hello, yo necesito un control remoto para mi dvdrw125, donde puedo conseguirlo. saludos.
The way I have it set up - cable box out to AKAI cable in, video and audio out of AKAI into TV via RCA. AKAI on channel 3, tv on RCA input. Change channels on Cable box, works fine. To watch a video, just put it in an hit play. Might have to change sources on AKAI if this is not working for u.
Posted on Apr 18, 2009
How do you connect AKAI model # PDP4290 to cable ?
You will need a cable box/set-top box with this TV. Contact your cable TV provider for this.
It does not have a direct RF connection, only AV connections.
For Cable TV support you can use
  • Composite video (single RCA connector)
  • SVideo (round 4 pin connector)
  • Component Connectors (3 RCA connecters red/green/blu)
Component will give you the highest quality signal (as long has the cable box supports this connection) You will also need to connect the Audio connectors (red/white RCA) from the cable box to the TV as well.
The full PDF manual for your TV can be found here: http://www.managemylife.com/mmh/lis_pdf/OWNM/L0502572.pdf
I hope this helps,
Magoo
Mar 11, 2011 | Televison & Video
The combi AKAI Aled 2402 gives the sign 'No signal' when I want to start the TV. What can I do? Please your reaction ! Jan
Are you using regular tv or cable or dish? If you have a cable or dish box, make sure the power is on and connected to the correct hdmi port or rca jack. Make sure tv is on the correct channel that the cable/sat/dish is plugged in to. If you are just using regular broadcasted tv, then you could have a poor signal or the tuner could be faulty.
Dec 31, 2010 | Akai Televison & Video
Turned on tv & cable box. Tv saids no signal. Check cable box works on other tv.
Issue with RF Module Tuner signal fail to initiate on the Video modulator Check for diode rectifier and capacitor leak
Sep 29, 2010 | Akai LCT2721AD 27 in. LCD Television
I'm trying to connect to my cable box but its giving me no signal what should i do??
If the signal output of the cable is being feed to the TV through COAX cable, then you need to set the TV to either channel 3 or 4 depends on the cable box RF OUTPUT setting. If you are using composite video (yellow RCA jack, RED and WHITE for audio) attach to Video 1 of your TV, then set TV input to Video 1.
Nov 21, 2009 | Akai LCT2785TA 27 in. LCD Television
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
No signal
do you have another tv ?? so you can test the cable.
sometimes the cable gets corroted by the distribution box and will obstruct any signal or if you do have signal " on another tv " the cable input on your akai is probably broken, if you have the skills try to open it up as see around the cable input box, most common they get un-solder or loose and won't detect any signal
Jan 08, 2009 | Akai LCT2715 27 in. LCD Television
this is a good one i had the same problem about a year a go on my brothers we tried every thing nout worked i said put the video leads in and do it it worked a treat but i have herd it don't work for all so it sounds like an amplifier my be needed hope any of this can help you. sorry if it don't only trying to help
Oct 11, 2007 | Akai LCT2785TA 27 in. LCD Television
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Connecting TV
If your tv has line out jacks, run cables to the "play" jacks in the back of the 300. If your running satelite, run the sound cables to the player instead of the tv. If your running a vcr player seperate, you can run those sound cable to the back ot the 300. The video cable would go straight to the tv.
Hope this helps.
Apr 17, 2007 | Akai DHT300 System
Akai DVDRW120 DVD Recorder Logo
249 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
