Question about ViewSonic VG2230WM LCD Monitor
Weird water-like image distortion
I have this ViewSonic VG2230wm quite a while now and i have the following problem. On the left side if the screen, while the resolution and refresh rate are of course what they are suppose to be, there is like a Distortion in the image, like its not syncing very well and if i put something like a text on the left side of the screen you can clearly see the letters somewhat trembling and shaking, its like very frequent water ripples. This problem though dissapears as you move more and more to the right, but its clearly visible to at least no the 1/3 of the screens horizontal length.
I've checked all of the options on the monitor's menu as well as the gpu's options. I've changed the connection from dvi to d-sub, changed the cables, even tried a different pc but its still there..
I dont know what else to do, im at the point thinking that the monitor is just broken. Please if you have any ideas or knowledge on this please share it with me.
Thanks in advance! :)
  • 1 more comment
  • Paramore Mar 03, 2009
    Thanks for replying ChipcircuiT but im afraid that i dont have enough knowledge in electronics to perform this that you are saying, but i never thought that it could be a power problem. Helpful! :) Its connected on a UPS unit though :/
    OK, the problem is fixed! The only cable that i have never changed was the problem, and that is the Power Cable! I've changed the power cable and now everything is sweet! :)
    It appears that the problem is still there, even though i changed the cable when i restarted it did the same thing, i had to turn off to monitor and then turn it on again and it got fixed.. it appears that i have to turn off and on the monitor each time I restart the pc.. Any clews?
    Scholar:
  • 157 Answers
This is electronic advice,dont do with yourself if you dont have experince about electronics,it will be very dangerous...if you have experience then you do this...
you open the lcd and you remove the power supply chips, it contains more capacitors like 1200mF 16v..i think so..but check the voltage if it is correct in the volt meter,caused the sounds like power distortion..if the voltage is less the screen will be "trembling and shaking, its like very frequent water ripples. This problem though dissapears as you move more and more to the right, but its clearly visible to at least no the 1/3 of the screens horizontal length." check
Posted on Mar 03, 2009
How to perform viewsonic VG2230wm red line removal?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 03, 2014 | ViewSonic VG2230WM 22 inch LCD Monitor
Removing back panel of a viewsonic monitor
There are almost always plastic clips along with the screws. I'd recommend buying a plastic pry bar. You can google for them online and they cost $1 or so.
Jan 30, 2013 | ViewSonic VG2230WM LCD Monitor
Viewsonic vg2230wm - the screen is blank when the computer first boots. I have to turn the monitor power switch on/off several times before the screen turns on, then it is fine.
Check your VGA (Visual Graphic Adapter) connector from your C.P.U (Central Processing Unit) to your monitor if it is intact. If it is intact , replace the VGA cable first. Then if the problem still persist check for the VGA driver in the device manager if it is correctly installed. If the problem persist try and send mail to me on greatengineerid@hotmail.com
Cheers.
Engr. Adewumi I.O
Sep 05, 2011 | ViewSonic VG2230WM 22 inch LCD Monitor
Screen stays black when coputer is turned on. have to restart
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Mar 25, 2010 | ViewSonic VG2230WM LCD Monitor
My Viewsonic VG2230wm refuses to use its native resolution of 1680 x 1050. Whenever I select this resolution, it registers on the computer display settings, but when I check on the monitor display panel...
You will need to adjust your monitor settings in the NVidia control panel. You can get to this by right clicking somewhere in a blank spot on your desktop and then selecting it from the menu. You will want to go into the Display section. If you aren't able to see that section, change from "Standard" to "Advanced" settings at the top of the screen.
Dec 31, 2009 | ViewSonic VG2230WM LCD Monitor
Monitor distorting in screen halves after warmup
It probably isn't worth repairing as the cost will exceed what you would spend on replacing it.
Sep 11, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Have a VG2230wm wide screen and the image trembles and bounces slightly, and the color is going from white background to pink. What would be causing this? The monitor is about two years old, it is set at...
This is due to a bad pin or bent pin or a bad connection isde the monitor or can even be a bad signal cable. Check all of these when in doubt check the solder points inside the unit.
Thanks hope this info helps please rate...
Aug 21, 2009 | ViewSonic VG2230WM LCD Monitor
Vg2230wm monitor Will not power on
probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
Aug 05, 2009 | ViewSonic VG2230WM LCD Monitor
ViewSonic VG2230WM LCD Monitor Logo
241 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
