Question about Amana ASD 2624 Side by Side Refrigerator
I have an Amanda side by side, the fridge temp
I have an Amana side by side, the fridge temp light keeps flashing, I have to put the temp at level 9 to keep the fridge cool.What is the problem please?
  • 583 Answers
Fridge side is not cold and freezer side ice building up on the back panel fan is working is it the thermistor causing that and how many ohm's thermistor should have
Defrost heater is open and needs to be replaced. Or maybe the defrost timer is no good along with defrost thermostat.
Check them out.
Nov 25, 2015 | Amana Refrigerators
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amana BX21VW refrigerator and both the freezer and refrigerator stopped cooling. The fan is still going and there is power, but no cooling of any kind. What is going on?
Hi!!
Check
Temp. control knobs,
Most likely, the evaporator coil is covered w/ice, obstructin the air flow thru it and to the fridge side of the unit.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure all ice is melted andthe air duct going to the fridge is clear.
Once this is done, restart unit and set temp. 1/3 of the dial, ie. if the dial goes from 0-9, set it on 3. wait 24 hrs to make adjustments
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Amana Refrigerators
Put in garage now unit will not keep cold or freeze.
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Water reservoir in bottom back of frig keeps freezing up.
Too cold in fridge if it is freezing is your milk or other items freezing. Check temp in fridge with a good thermometer.
Nov 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side fridge and freezer not cold.The model #ASD2624HES I have done some research and I think it might be the relay switch or the compresser.If anyone had has this problem with this model...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Part 4 on this diagram is your relay. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2624HES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATION&diagramPageId=00013&componentDescription=COMPRESSOR&documentId=M0608085&backToLink=Return%20to%20subcomponent%20list Here's how you can check it. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 22, 2009 | Amana 26 cu. ft. Side-By-Side...
Flooding when freezer defrosts
Make sure the refrigerator is level and the drain tube is not clogged. This is the most common cause of water pooling.
Jul 29, 2009 | Refrigerators
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
Amana ASD 2624 Side by Side Refrigerator Logo
195 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
