Question about RoadPro 12-Volt Coffee Maker
Replace 12 volt plug
I need to replace my 12 volt plug, where can these be located keeps blowing and melted in outlet, thks
  • stberinger Mar 19, 2009
    I'm looking for a mini atm or sfe replaceable fuse 12 volt plug so that I can replace my broken burned out one on my coffee pot. The plug and wiring needs to be able to handle 20A. I would like to repair it and not throw it out. thks2
No power to outlet on drivers coach side
Locate the 12 volt fuses. Not all coaches have them in the same location. Some are in the power converter, other locations are inside cupboard doors . Once you discover the location of the fuses, one of them will need to be replaced.
Mar 12, 2016 | RVs
My 2008 suzuki grand vitara keeps blowing the fuses for the ACC outlets. both are 15AMP, but even with nothing plugged in, nothing down in the outlets and even with larger AMP fuses, they keep blowin
If you use too large a fuse, the wiring can catch on fire, and the whole car could burn up. You'll need an auto electrician to trace that problem. You can remove any bulb and unplug any device that is on the Acc(essories?) circuit; then see if a fuse will stay; start replacing items till you blow the fuse. It seems like a dead short which can surely melt wires if you keep taking chances. good luck.
Feb 14, 2015 | 2008 Suzuki Grand Vitara
Keeps blowing fuses when unplugged from the wall
you need to replace the outlet your plugging it into or go to a different ciruit in the house n try again.
Jul 19, 2013 | Televison & Video
Is the 9 volt a fuse
Where do you have a 9 volt? I'm assuming you mean the outlet that we used to call the cigaret lighter? If so, it's a 12 volt outlet. Its pretty common for this fuse to blow, I'd definitely check that first. Get a few fuses because it likely blew from a bad accessory you plugged into the outlet. Also, try a few different accessories and verify that it's not an issue with the one you're plugging into it. If you replace the fuse and it blows again then the problem is being caused by whatever you're plugging into it.
Jan 18, 2013 | 2003 Volkswagen Jetta TDI
I am having a problem with my 12 volt power outlets. Ever since I used an iPod FM transmitter in both of my outlets, neither outlet works for any accessory that I plug in. The fuse was blown, I replaced...
I think you need to look inside of the sockets for foreign objects such as change or foil from gum wrappers. This is the most common cause of this problem. If it is all clear we need to unplug both and put in a new fuse, plug in one and then the other, see which one is the bad socket.
Jun 07, 2011 | 2005 Ford Taurus
Ignition module on golf keeps on blowing up.takes about 1 min.then it cooks .
you need to ckeck the wiring harness going to the module. sounds like you have short and maybe some of the wires have melted together. this would cause a 12 volt back feed and fire the module
Jun 13, 2010 | 1992 Volkswagen Jetta
I have a Whirlpool refrigerator, Model # ET18NKXFW0 1, Serial # EG5130791. It has working fine for 12 yrs. I recently moved it from one location to another in the back of a pickup on its side. As soon as...
Refrigerators should never be plugged into a GFI due to the start up amps that it draws on start up. With other items on the same circuit it is too much of a load. Refrigerator need to be on there own individual circuit to keep this from happening and not a GFI. Hope this helped.
Feb 02, 2010 | Refrigerators
My cigarette lighter is not charging in my car what could it be?
You mean there seems to be no power to the vehicle's lighter unit outlet.
This lighter unit outlet is normally wired through its own fuse so check the fuse panel in the car for a blown fuse. If blown it must be replaced with a fuse of the correct amperage. The owner's manual will show you where the fuse is located.
Before you check the fuse just check the cigarette lighter outlet with another plug-in device if you have one such as a portable 12 volt tire compressor or a 12 volt plug-in auxiliary light. It could be that if you are using a charger from the outlet, the charger plug or wiring may be faulty rather than the car's power outlet itself. (These outlets don't usually give trouble unless the wiring has been messed with or the outlet itself has been damaged or abused).
If no device works from the lighter power outlet check the fuse as it may be blown.
Sean
Voluntary contributor.
Dec 27, 2009 | 2006 Ford Taurus
1996 Cavalier 12 Volt power outlet in car doesn't work right?
Even thought the plug in is 12 volt. It's ouput is different. Most electronics have different ranges from 3-9 volts.
Does the 12 volt charger put out 12 volts? If so, it would burn up the electronics' capacitors on their power supplies.
How is the car's electronics doing? Are they too failing? If so, that would be a faulty voltage regulator, if not, I would hook up anything you use to the radio wires.
You cannot plug in anything directly to battery no matter what the person told you. Batteries charge, than release charge, a contiuous cycle. The power output is speratic and anything hooked straight up to the battery will need a fuse.
Jun 08, 2009 | 1999 Chevrolet Cavalier
The heater plug melted
Induction coil heaters draw very high amperage (12-14 amps) when turned on. If your outlet is worn or old the heater plug prongs will not have a good connection and the current will jump or arc from the outlet to the heater plug prongs. This arcing causes tremendous heat, enough to melt the outlet and the cord end. First thing to do is change the outlet.
Jan 31, 2009 | Dimplex Compact Electric Flame Stove...
RoadPro 12-Volt Coffee Maker Logo
82 people viewed this question
Top RoadPro Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a RoadPro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
