Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
I have a 55 inch Akai rear projection tv.When I turnit on,the red timer light blink,and that is all.I've heard about this problem on here before.No pic and no sound
  • Gary Hinkle Mar 03, 2009
    The fuse is I will try everything else that anyone can suggest.
  • BNLR Mar 06, 2009
    when i turn the tv on the red light blinks but nothing else. the tv itself will not turn on, no sound no picture. However when i hit the power button again it won't turn it "off" i have to unplug it.
    any suggestions besides the fuse?
  • 583 Answers
On the main board of the tv there is a fuse located if that is faulty this can happen,there are also many other possibilities but check out the fuse first many a times replacing the fuse solves the problem as its very negligible to replace the fuse the cost of fuse is under $1.
Posted on Mar 03, 2009
I have an AKAI TV...Model Code #PT4250AX/SMS - Rear Projection TV. The TV was being used and a pop sound was heard and then the tv was black (no audio, no video). Now when you turn on the power the red...
My recommendation is to call a local svc co. Since you heard a pop, it could be anywhere in the set. It requires trouble shooting to isolate where the problem is. I hope this is help-full for you.
Feb 27, 2009 | Akai PT4298HD Rear Projection Television
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
TV will not turn on
Replace shorted Q431,can use a 2sc3998, open r448 .47ohm resistor. after you get set on beware of convergence ic's may have been shorted causing all the problems.Check r859 &r858 .47 ohm 1 wtt that supply - &+ 20 volts to convergence packs, if open replace packs & check low ohm resistors on convergence ,I found r2144 &r2145 open replaced & all systems go "good luck"
Dec 26, 2008 | Akai PT5598HD 55" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
AKAI 54 inch
sounds like your convergance ic's shorted on you.
you can replace the fuse in the power supply and disconnect the conv board and see if it comes on. if so order new ic's and check all resisters for the correct values.
good luck
Jun 09, 2008 | Akai PT5598HD 55" Rear Projection...
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD
Dec 17, 2007 | Akai PT5598HD 55" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
All kinds of weirdness going on...
hi maybe your connections are poor try changing them and see if it works out but it sounds like a solders problem: they are dry or broken try and see if you give it a small tap on the side the picture shakes\dissapears\working good at last if soo then its that i guess that you dont have any electric background soo you will need to take it to a tech gay good luck
Mar 21, 2006 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
271 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
