Question about HP (FA302AAC3) for IPAQ Rz1700, Hx4700 Series Keyboard
Touch pad not working on my ipaq hx4700
Finger/mouse pad not working on my ipaq hx4700 the other 4 shortcut buttons function OK - Stopped working after I dropped it! everything else is working fine.
  • 1,602 Answers
Open the device and check the componets are not shorting out, when you droped it, with that much force you may of bent the leads inside or broken, if it bent you can fix it but you broke it than it is time to buy a new one, check the power source for that switch make sure it is okay.
you may of knocked something out of alinement.
rodgandysr567
Posted on Mar 04, 2009
Why has my mouse stopped working, also the touch pad on computer has stopped?????
Janice, This is info from Tomsguide.com
1- Turn off computer, disconnect the power cord, remove the battery.
2- Press the Power On button for 10 seconds
3- Replace battery and/or connect power cord.
4- Turn On computer + immediately press F2 key repeatedly
5- Press F9 then press Enter
6- Press F10 then press Enter
May have virus or corrupt driver, run your anti virus and try reloading divers for mouse and touch pad, you may have to use system restore to an earlier date when thins were working OK.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ccm.net/forum/affich-689275-toshiba-satellite-mouse-pad-stopped-working
Toshiba Satellite keyboard and touchpad don work
Toshiba Satellite Cursor is not responding
Jul 31, 2016 | Toshiba Computers & Internet
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
The touchpad above my keyboard is no longer responding as I think i may have deleted something from the hard drive. how do i fix this? When I first recieved the computer the majority of the touch...
sure you deleted something, how else can a driver just go byebye.
NO OS stated is this XP
we cant guess what OS is there ever.
so does mouse work, usb plugged in , that be first.
after checking device manager, for touch pad , driver errors
then know a pad this old can be bad.
it can also be set wrong in control panel, click mouse
and set it as you like.
Feb 18, 2018 | HP Pavilion DV9720US Notebook
The touchpad (and buttons) stopped working. No response at all. External mouse works fine, so it is not a software issue. Could this be a loose connection? or do these fail after a while? Are the...
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
Jun 25, 2010 | Toshiba Satellite M55-S325 Notebook
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
Mouse pad just stopped working on start-up today. Works with external mouse. Pad and left & right buttons just dead.
You may have turned it off. Check your "function" or "f" keys or the on/off button may be above the touch pad
Mar 20, 2010 | Averatec 7115 EHI 17" Notebook PC Notebook
HP iPAQ hx4700 need default password
If you can't remember your passcode, you may have to do a hard reset(factory settings) if you have a sync folder on your computer, there is your backup. To do a hard reset: 1. Remove your iPAQ from the cradle, making sure that it's running on the internal battery power. 2. Use the stylus to press down the recessed reset button on the back or side of the iPAQ. 3. While the reset button is held down, press the On/Off button. 4. Release the reset button. When you press the On/Off button again, your iPAQ turns on and all your files are gone. To avoid repeating this major disaster in the future, you should back up your iPAQ files on your desktop PC. Activesync will generate another folder,and you will have to rename your pocket pc. But once your past that point, open both folders and drad and drop into the new folder. Hope this helps.
Jan 25, 2010 | HP iPAQ HX4700 Pocket PC
Touchpad scroll is not working in my laptop lenovo 3000G430
download synaptics pointer device off the net its free.
Aug 14, 2009 | Computers & Internet
HP Ipaq 4700 stylus problem
ask HP yet, we are not HP , sorry and this thing is legacy retired product , what good is it?
here is the real HP forum
see if you can get tears there.
https://h30434.www3.hp.com/
Dec 02, 2017 | HP iPAQ HX4700 Pocket PC
HP (FA302AAC3) for IPAQ Rz1700, Hx4700 Series Keyboard Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
