Question about Fuji FinePix S7000 Digital Camera
Will not auto focus
I have had this S7000 for some years now and this is the first problem it has given me. It's like the auto focus is turned off. Is that possible, could I have hit a button and done that???? I'm still looking through the user guide, but could use a little help.
Thanks
  • 2 more comments
  • Uturn22 Mar 03, 2009
    Good call, the switch is on the left side of the camera, it was on MF. This is great. Thanks form the help.
    Uturn22
  • ddh818 Apr 18, 2009
    i have the same problem but my button is on CAF.  If I look through the view finder the image is blurry, what could be wrong
  • pink627 May 24, 2009
    my camera is on c-af mode but it is still blurry.i cannot focus my camera but everything is blurry
  • phiah May 24, 2009
    had my camera for some years, occasionally hit the button on the side and got blur, lately I get blur even though the button is in the right position. Sometimes I can shoot 2-3 pics before the problem occurs and after it gets worse and worse.
Hi again, took my camera to a shop and they figure it is really sick and needs repair/change the autofocusdevise. They called the Fuji company that claimed they did not no of this problem, so no extended guarantee:( Would appreciate if you guys who have the same problem can clarify whether the advice about the switch helped you or not. Thanx a lot.
Posted on Jun 04, 2009
    Scholar:
  • 73 Answers
There is a switch on the top of the camera that has your focus modes. switch to C-AF for Continuous auto focus. If you have it set to MF - Manual Focus that would explain this easily.
Posted on Mar 03, 2009
My camera's view screen is shaking and my photos are out of focus
It appears that you have an auto focus issue. Yes, it is repairable but at what cost? The part son those cameras are proprietary and cost a small fortune not to talk about the heavy labor involved in making the repair.
Does the manual focus work?
Mar 07, 2016 | Nikon COOLPIX Cameras
Auto focus is to slow
Try pressing the button down all the way quickly. If that doesn't work just play with your settings until it works.
Jan 09, 2013 | Fuji FinePix S7000 Digital Camera
Photos are purple and green, it does not focus properly Is my camara finished or is it worth repairing it is about 4 years old s7000 digital.
HI there if your focus having problem then the images will come blury. But as per your problem its a lens sensor error or problem. Just replace the sensor and you will get the proper colored image. Thanks.
Mar 19, 2010 | Fuji FinePix S7000 Digital Camera
Shutter lag on fuji finepix s7000 - is there a solution ?
2 things - you could do 1 or both, depending on the photographic situation:
1) If you can choose manual focusing, select manual focussing & prefocus on subject. This eliminates the need to refocus. I do this lots with the S9500 model.
2) If you can shoot in manual mode, use auto exposure to see what shutter speed & aperture the camera selects when the camera is pointed at the ground (or other suitably lit spot). Change to manual exposure & set the aperture & shutter speed indicated by the camera in AUTO mode.
Once you do either or both of these you will get instantaneous shutter release.
Practise on unimportant subjects first and see how you go.
Apr 10, 2009 | Fuji FinePix S7000 Digital Camera
My Fuji S7000 wont focus when I use a wide angle lens adapter.
I've since found out (via a Fuji forum) that the camera MUST be set to Super Forced Macro for the lens to focus ..... which it now does!
Aug 23, 2008 | Fuji FinePix S7000 Digital Camera
Fuji finepix s7000
I just then took the previous posts idea and pulled the lense off and cleaned light sand out of it , extended lense as told, put back together and turned on.so far focus seems good
Apr 29, 2008 | Fuji FinePix S7000 Digital Camera
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
Scrambled focus of all subjects
Hello there I was having that same problem with my S7000 before my CCD sensor stopped working, the horizontal lines i had were black and blue. Hope you dont have the same problem as me.
Oct 04, 2007 | Fuji FinePix S7000 Digital Camera
Using my camera
IMHO ---- A lot depends on the lighting available for shot, outdoor and bright is best. Use AP setting (dial on top), Aperture Priority, and set desired F number (using thumb wheel, top right edge) as high an F as you dare, taking speed used into account, by watching it change in viewfinder (do not want a shaky slow speed!). The depth of field, hopefully with higher F, will be deep enough to catch back and front rows, in focus. A half press on shutter should trigger auto focus and give chance to preview in viewfinder. Good luck hope the weather behaves. Less light = less flexibility.....
Jun 23, 2007 | Fuji FinePix S7000 Digital Camera
Camera will only focus in macro mode
Check house not inadvertently set it to macro. If it has manual focusing try to reset the focus collar - check the manual for something you may have overlooked Failing all that look up the Fuji Tech Support team in the website
May 24, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
212 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
