Question about Sharp Office Equipment & Supplies
I have an old sharp sf-7200 that has a toner light that keeps flashing in spite of me refilling the toner collection unit. Can anyone help? Tried re-inserting toner unit several times, cleaning top edges, etc. Thanx
  • 29 Answers
This copier need new developer and calibrated properly
its very old and really worth the trouble
Posted on Mar 09, 2009
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
I have a red triangle flashing and the copier sounds like it is trying to warm up and then does nothing. what is going on?
Hi, this triangle means that the toner is empty. This can also be caused by a defective developer unit drive gears. Check that it is okay if not replace the gears. Replace the toner cartridge or refill the toner in its unit. Make sure you empty the waste on its side as it may cause some noise or toner spills. Use cartridge Sharp Al100td or refill with Sharp Al1000 toner bottle. All the best.
Nov 23, 2010 | Sharp AL 1631 Copier
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
I own a sharp SF-7900. My pages are coming out black
I'm sure you may find a manual, but your copier is rather old.... When you make a copy do you get a error code? How about when you make a copy, do you see the scanning lamp turn ON? Here is you thing you can try, make sure the Primary Corona unit is pushed in all the way in. It has a grey handel on it and it should be found right above the Drum... Good Luck
Apr 19, 2009 | Sharp Office Equipment & Supplies
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Adding developer to sharp sf-2025
Hi, it means the developer requires changing. it has a life of 30k (i think). I would suggest that if your quality is not effected, then keep using the machine, or spend the money on an engineer to come out and replace it.
Feb 28, 2008 | Sharp SF 2020 Copier
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Oct 18, 2007 | Sharp AL 1631 Copier
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
