Question about Amana Radarange Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
  • 583 Answers
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Posted on Mar 03, 2009
MICRO WAVE DOOR FOGS UP WHEN USING IS THAT NORMAL
A Microwave Oven works by heating water/moisture in food: if the boiling action (e.g. when boiling water) is greater than the oven exhaust fan can cope with, then the inside will steam up and fog the door glass: this is usually OK and 'normal' (this is actual the advise in cleaning up the interior of a microwave oven - steamy soapy water - see your manual).
Hope it helps.
May 16, 2011 | Hamilton Beach Microwave Ovens
My 7qt slow cooker glass cover doesn't have a small hole for the steam to escape, so while it's cooking it is continually lifting the cover spitting out water and dripping over the whole counter, is that...
The slow cooker works by heating the food up to around 85 degrees Celcius and should not boil. If you have it hot enough to boil place a tooth pick under the glass edge. That will let the steam out.
Jan 13, 2011 | Microwave Ovens
HOW TO GET SPATTER OFF ADVANTIUM 120. SOAP & WATER DID NOT GET THE JOB DONE
easy stick a bowl of water and stick it in the wave and boil it.. but be careful to let water cool before you open the wave for a minute or two ! the steam from the super heated water will loosen that stuck on mess .. boiling water in a m wave is dangerous the water will explode when exposed to cool air
Jan 31, 2010 | GE Advantium 120 Convection/Microwave Oven
Whirlpool micro wave making loud humming noise fan and light works
Some micros when they get older make more noise. as long as it works I wouldnt worry about it
Jan 12, 2010 | Whirlpool MH7140XF Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
I was boiling water on the electric range beneath my FRIGIDAIRE FMV157GC 1.5 Cu. Ft. Microwave Oven when there was a loud snapping/popping noise occured. I immediately shut off the microwave and thought...
I would say the transformer for the power supply has probably shorted, or another major component in the power supply has shorted - This may be repairable if easily spotted, but most likely will not be cost efective.
Sep 04, 2008 | Frigidaire Microwave Ovens
My micro wave will not heat products. All other systems are functional.
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 08, 2008 | GE Microwave Ovens
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
Heard a loud glass breaking noise, now micro-wave will not heat anything. Turntable works, everything looks fine but no heating. Model#R-1505LK
Does it seems to run louder?
I would suspect a shorted high voltage rectifier diode.
We have the full service manual and have uploaded it to our site here.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 19, 2008 | Sharp Microwave Ovens
Amana Radarange Microwave Oven Logo
508 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
