Question about Krups DuoThek Plus 464 Coffee Maker
The left side of my Krups Duothek Plus 464 is not working
The hot plate does not heat up; water will not heat up or go out of the water container. I assume it's the heating element or something like that. Any hints? Thanks!
  • 583 Answers
I have a krups mk7000, quit working, changed filter, no water comes out and hot plate is cold, Jim
the thermal fuse has blown and needs to be replaced , if unit gets too hot it will blow it is very small possibly in heat shrink tubing crimped on the AC cord inside, need a test meter to check for current. need heat to boil water to rise to the filter and so on. these thermal fuses sometime are 2 check all in side the machine , can be replaced for about $8-10 dls us each @ Radio Shack should be 8-10 amps .187 diameter .625 length >^.^<
Mar 19, 2010 | Krups Coffee Makers & Espresso Machines
A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Dec 16, 2009 | Krups Small Appliances Espresso Machine
Krups KM7005 coffeemaker/grinder does not heat or drip the water
The heating plate is actually your hot water heater for the unit and it has most likely failed. The water flows through the heating plate and heats the water for brewing. Krups replaced my whole coffee brewer.
Dec 15, 2009 | Krups Small Appliances Espresso Machine
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
Krups KM7000 won't brew
Your heating plate is your hot water heater, and most likely failed. Krups replaced my whole unit.
Oct 07, 2009 | Krups Coffee Makers & Espresso Machines
How do I descale a Krups Dolce Gusto machine?
_451.jpg_450.jpgSorry about picture quality, fixya only let you upload small file sizes
Aug 21, 2009 | Coffee Makers & Espresso Machines
Krups km7005 water not heating nor hot plate
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbech, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Aug 01, 2009 | Krups Small Appliances Espresso Machine
Krups model KM7005 water wont heat
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Jun 02, 2009 | Krups Small Appliances Espresso Machine
Apr 10, 2009 | Krups Coffee Makers & Espresso Machines
Coffee Not Hot Enough
probably need to descale the machine scale stay on the heater and doesnt heat as much use descaler not vinegar thanks pierre
Jan 11, 2009 | Krups Small Appliances Espresso Machine
Krups DuoThek Plus 464 Coffee Maker Logo
166 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
