Question about ASUS K8N-DL Motherboard
Can you run a pci-e 2.0 video card in a pci-e 16x slot?
I have an Asus k8jn-dl mobo and I'm considering upgrading my 7600 gs vid card.
I'm pretty sure the pci-e slot is not 2.0 but I was hoping to get a 9500 gddr3 or thereabouts. Can I run it?
Is it even worth it if I can, or will the motherboard slow it down enough that I should only get an 8600?
  • paleus Mar 04, 2009
    Thanks very much :D
  • 239 Answers
If you install the 9500 in your computer it would probably malfunction. even if it did happen to work it really wouldn't be worth it as it would clock down to what your slot was made to use. better off getting the 8600 card. which is a very decent card will run your games just fine.
hope this helped please rate well.
Posted on Mar 03, 2009
  • 81 Answers
Even if it works (hard to tell) the output will be limited by the speed of your pci-e 1.0 bus, so the extra power you are paying for won't be noticed. It would be better to get a card designed for your hardware.
Good luck
Hello,I can't connect this card to PCIex16 female J41
You can't use that card in a PCI express slot because that specific video card uses an AGP connector (which is no longer a supported card interface). You will need to use a motherboard that has an AGP slot.
Feb 13, 2015 | Nvidia model-p118 - Model P118 Geforce4...
Hi I have a supermicro x8sti Server Board inside
Basically you have two choices for installation of video card:
1. To purchase small form factor PCIe card suitable for installation on 1U server chasis or
2. Purchase PCI express riser card and to install most full-sized PCI Express cards (Check this link for PCI Riser )
Oct 04, 2013 | SUPERMICRO COMPUTER Supermicro X8STi-F...
I have the Board ASUS P5VDC-MX. And I wonder that there is no pci-e slot, but in the information there is written:"this board is pci-e (16x) ready".... is it right ? Can i use a pci-e (16x) video...
No, you can't use a PCIe x16 card in any of the slots on the P5VDC-MX board. A PCIe x16 card can't fit into the PCIe x1 slot. Attempting to force a PCIe x16 card into the PCIe X1 slot will break the card or bend the pins. A PCIe x1 card will work in a PCIe x4, x8 or x16 slot, though. Similarly, the AGP and PCI slots are not compatible with the PCIe x16 card design.
I wish that I had better news for you.
Aug 19, 2017 | ASUS P5VDC-MX (P5VDCMXGREEN) Motherboard
Nvidia graphics card won't fit in asus ncch-dl motherboard
The NCCH-DL has the following slots:
1 - AGP-Pro 8x
(you can use regular AGP cards in here as well as long as you have the little plastic thing that comes with the mobo... you may even be able to without it)
2 - PCI-X
This is NOT PCI-E.
You CAN use regular PCI cards in a PCI-X slot IF the company that manufactured the card left the space between the little metal contacts... unfortunately, many PCI cards are made with the space filled in with useless plastic... I've heard you can cut the little space yourself and it'll work fine... I don't know why it wouldn't but be careful, and of course do at your own risk.
I currently use a regular PCI network card in this slot because the onboard LAN port only has Win64 bit drivers on the web site and it works just fine.
A PCI-E card will NOT work in this slot.
Generally speaking the PCI-X cards you are going to find are riser cards, network cards, firewire cards, and controler cards.
2 - Regular PCI Slots.
I think you know what PCI is.
May 03, 2009 | ASUS NCCH-DL Dual...
Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Feb 06, 2009 | ASUS Computers & Internet
Which latest Graphic card can be supported by my Asrock P4i45GV?
Any video card that supports AGP x8 Should work on this motherboard.
For example Nvidia 7800 GS AGP or 7600 GS AGP should work fine.
But a better investment would be to upgrade the motherboard to a PCI-E supporting board and possibly AMD Dual or Triple / quad core processor the ram is very cheap for DDR2 these days.
Upgrade would be best in long run.
Feb 02, 2009 | Asrock P4I45GV R5 Motherboard
Graphic card
Yes you can use either Geforce 7300 or 7600 on this motherboard they are compatible with it, there shouldn't be any compatibility issue abetween this MOBO and any of those video cards...
Hope that helps...........
Sep 08, 2008 | Computers & Internet
Vga compatibility
It appears that that model is AGP slot based, so it would not work in a PCI slot.
Aug 31, 2008 | ASUS P5VD2-MX Motherboard
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
Pci express X16 slot one no longer works
If anything, the BIOS would have disabled slot one. You can try looking in there to see if you can find a setting to reverse it, but it sounds like you're out of luck. Seems like the slot has been KO'd.
Apr 07, 2008 | ASUS A8N32-SLI Deluxe Motherboard
ASUS K8N-DL Motherboard Logo
184 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
