Question about Plumbing
Steps to using allen wrench
How do I go about replacing the cartrige
  • 297 Answers
First make sure the water is off to the unit.you may have to turn off the entire house,some times,remove the handle then pull the sleeve off, in fornt is a small pin pull up pin pull out cartridge,replace in reverse order.
Posted on Jul 22, 2009
Master Lock 34AT trailer coupler lock. key turns tumbler 90 degrees, but lock wont remove. I don't know if i'm supposed to use another tool (like allen wrench) for pinhole in bottom. Is there...
Instructions:
1. Insert key in cylinder and turn to right.
2. Slide trailer lock over side flanges of coupler as far as it will go.
3. Insert allen wrench (or screw driver) into opening at bottom of lock and turn it to right until hardened set screw is tight against inside of coupler. Remove wrench.
4. Turn key to left and withdraw it. Opening for wrench is now blocked.
(To remove lock, merely reverse above steps.)
Jun 12, 2011 | Master Lock 34AT Trailer Coupler Lock
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
I have a Kohler K161024 bathroom faucet which is leaking around one of the handles. I contacted Kohler and was sent a replacement part, but there were no instructions on how to install the new part. How...
first to take the handle off you need a allen wrench set, then the base should unscrew to reveal the part thats leaking, channel locks should do fine to remove the cartrige....
Jan 26, 2011 | Kohler K-16102-4-AF Revival Widespread...
How hard is it to replace a rear strut
it is fairly easy
1. jack up remove wheel, block car on frame!!! not on the strut
2. remove two big bolts on bottom of strut then have to drive them out of hub housing (splined about 1 inch on head side of bolt.
3. remove the sway bar connector rod (allen key and wrench. or if allen is stripped u can use wrench just in front of boot, so one inside and undo the one nut you can see facing you)
4. open trunk pull carpet back on top of wheel well so you can see 3 nuts in a triangle with one in the center DO NOT REMOVE CENTER NUT this is what holds spring to strut assembly..put a jack under strut to hold it in place .remove the 3 nuts.
5. pry the bottom of strut out of hub
6. drop out strut and spring assembly.
7. use 2 spring depressors to squeeze the spring so u may remove large center nut, use wrench and allen key.
8. replace as a whole unit or just the strut. the whole unit is more expensive and if so delete step 7
9. reverse the steps to install.
10. make sure all bolts are tight and check with torque wrench for proper tightness.
11. MAKE SURE LOL you dont want to go for a drive with any of these parts loose. If u r not experienced take it to a shop.
Dec 05, 2010 | 1998 Pontiac Grand Prix
How do I change the treadmill band on a 9500hr commercial treadmill?
Step one: remove the screws to calibrate allens belt in the opposite direction clockwise allens wrench 5 / 16 "
Step two: remove the screws above the deck allens wrench 5 / 32 "
Step three: with a flat screwdriver to lift the lever of the Idler belt and remove the drive belt motor pulley. be careful
Step four: remove the rollers carefully.
Step five: Remove the deck
Step Six: Remove the philips screw that holds the spray nozzle
Step seven: now carefully remove the belt.
to install belt now repeat these steps from back to front Once installed you must calibrate or belt slack to avoid turning the screws slide the meaning allens counterclockwise you can start with a speed 1.5Mph and increasing to 4.5Mph any questions send me an E-mail to cardiotech_me@hotmail.com
Aug 25, 2010 | Life Fitness 9500HR Next Generation...
I need a Master Bilt Cam Wrench to disassemble a Walk-in freezer. What can I use and where can I find it?
All the walkin coolers that I have installed use a allen wrench and I beleive it is 3/8 inch. Try allen wrenches first. Rus
Dec 03, 2009 | Master Bilt Indoor Walk In Cooler or...
Change oil fork
There is a bit of directions on how to change the oil. I will give you a link to a site that has pictures with step-by-step directions that will work for any bike fork.
http://www.bluepoof.com/motorcycles/howto/svs_fork_oil/
If you have any more questions, feel free to ask..
Nov 25, 2009 | 2004 KTM EXC 200
I lost my instrction manual!
Step 1: Detach the front panel from the 2 front post using an allen wrench
Step 2: If the mattress support is not in the lowest position unscrew the bolts and move it to the lowest position
Step 3: Using the allen wrench, attach the guard rail using 4 bolts between the lest and right front post (the guard rail would be that extra piece that you couldn't do anything with while the bed was converted to a crib. Looks kinda like a wooden board)
Step 4: Tighten all screws and put the crib mattress back in
Apr 30, 2009 | Baby Gear
Can anyone give me step by step instructions on how to remove light engine from sony kdf60wf655 tv thanks
I have the same Sony TV and just replaced my bulb. I ordered the bulb from sony.com and the package included the allen wrench you will need and simple step by step instructions are also included. There are two hand tightened screws on the lower rear corners of your TB. Remove these screws by hand and remove the botton gray panel of the TV. You will see the light package in the bottom center. Remove the hand tightened screw and swing the metal holder away. The gray cover now will come off by pulling lightly on the bottom. This will expose the lamp. You will need the allen wrench supplied with the bulb to remove the allen screw on the left. Once removed, the plastic cage containing the bulb will slide straight out. Push the new bulb in and tighten the allen screw. Replace the gray cover and swing the hold back in place the hand tighten the screw that holds it in place. Replace the gray bottom panel and hand tighten the two screws on the lower rear corners. That's the whole deal.
Jan 17, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Broken timing belt. how hard is it to replace?
Ok here is were you need to go http://www.dsm.org/tsbs/tbelt/tbelt.htm - DO THIS STEP BY STEP
Replacing your timing belt is very easy IF YOU KNOW WHAT YOUR DOING. What I suggest doing is bring it to a shop. But if you follow the directions you can do it in 2 hours tops. But for a personal note. When you get to the timing belt tensioner. Unbolt the tensioner from the car (two bolts), put it in a vice and SLOWLY compress the pin in. Then take a very small allen wrench and put it in the gernade hole (you will know what i'm talking about). Then Bolt it back in to were it's really snug. Then after you have your car timed, put a pair of needle nose pliers on the allen wrench and then put a long screw driver in between the timing belt and the allen wrench and yank out the wrench really fast. YOU DO NOT WANT IT BREAKING INTO THE TENSIONER. GOOD LUCK.
Jul 29, 2008 | 1990 Plymouth Laser
Plumbing Logo
43 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
