Question about HP Photosmart C3180 All-In-One InkJet Printer
Our HP Photo Smart C3180 All in one Printer seems to be advancing the paper faster than it prints at times causing blank lines to appear on both documents and photos.
  • 523 Answers
The problem is the drivers that are not xp compliant, check this if doesnot work, it will be hardware problem. let me know what happen so i will let you know which part you have to change.
Best Regards
Posted on Mar 03, 2009
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Photos print too redish; blues are purplish
Photo Prints Slowly on HP Advanced Photo Paper
... 8250, 8250xi and 8250v Printers - Photo Prints Slowly on HP Advanced ... Prints Slowly on HP Advanced Photo Paper - c00564372 ... 8250, 8250xi, and 8250v printers print a photo on HP Advanced Photo Paper slower than expected. The ... s.gif » Choose the Best Ink Cartridges for Your Printing Task
Choose the optimum combination of ink cartridges to enhance photo quality. s.gif » Printing Photos from a Memory Card
... to view, select, enhance, and print photos. You can also print camera-selected photos, photos you ... in the Main tray or Photo tray. Check the Photo tray light to verify that ... Load photo paper. Check the Photo tray light to verify that ... s.gif » Problems Printing from the Photo Tray
Instructions and troubleshooting on photo tray printing issues.
Aug 27, 2008 | HP Photosmart 8250 InkJet Printer
The colors on my C3180 inkjet were fine and now are not, including lines across the page. I've just 2 new cartridges and 2 different kinds of photo paper. What do I do?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 26, 2011 | HP Photosmart C3180 All-In-One InkJet...
It won't print photos correctly because it only prints part of the photos
While this may be a mechanical fault, and if so a service call is going to be required to fix it, it can frequently be caused by software settings for the printer drivers or for the software being used at the time the photo is being printed.
When you select print from the software the usual response is for the printer driver's dialog box to appear. Within that box is a radio button which is usually marked "Page Setup". Selecting that button will access settings for various paper types [which can effect the problem you are having if the wrong one is high-lighted] as well as various other feature settings which can effect the printers output.
The support website for your specific printer should have information on what settings to change to realize desired results.
In software, like Photoshop for instance, settings for image size can effect the printed end result if the settings are a mismatch between photo size selected and the photo paper being used [unless there is a "fit to paper" option checked in the aforementioned printer driver page setup dialog box]. Like having those settings set to print an eight by ten print on four by six paper, for example. These settings should be checked to make sure your selected photo print size matches the paper you are printing on.
Hope that helps.
Feb 04, 2010 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
Kodak photo paper
maybe its a bit thick the paper try a different make. poundland do a good one.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
Cannot Print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 20, 2009 | HP Photosmart C3180 All-In-One InkJet...
Custom Paper Sizes for HP Photosmart C3180
I have a 3100 series HP. On it you select "Properties", then the "Features" tab. On that tab, there is a "Resizing Options" menu item. It has a drop down menu with "Letter", "More...", and "Custom" choices. There you can define the size.
Oct 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180
Do you know if that control panel in you computer for that printer needs to be told that you are printing pictures?
Some models you do by selecting photo paper.
Jul 05, 2008 | HP Photosmart C3180 All-In-One InkJet...
Unable to print
try doing partial reset of ur printer
Jun 12, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
91 people viewed this question
Ben Johnson
