I have a hunter J111 alignment machine. When I go to set castor and you get to the screen that shows all four wheels are lit up green and even numbers then when you are supposed to turn left as soon as you do then the left front sensor starts blinking the red fault arrow and will not change, If you turn the wheels back to the front you get the all green lights and numbers back. If you stick your hand in the IR beam it takes the numbers from 150 down to 30 then remove your hand the numbers and green comes back?
  • 1 more comment
  • iupholster Mar 03, 2009
    Report abuse
    posted by iupholster on Mar 03, 2009
    Tied reinstall system disk did not work, don't think it is the sensor or it wouldn't work on the camber setting either?
  • iupholster Mar 05, 2009
    Have tried all suggestions, none of them work. I know the wensor is not the problem have changed the sensor to the ohter side it works fine.
    Sorry but not satisfied with my purchased help.
  • Brian Seisbye
    Brian Seisbye Jul 29, 2014
    Anyone that can send my a "backup" of factory disk? (image) or somefing?
  • 20 Answers
I have extensive knowlege on this machine. If you are still having the problem, there are very few things that could be causing it, assuming that it is a conventional problem.
This is NOT a software program. For all of you out there, the Hunter J111 in not windows based. There is no software to reload, besides the factory disk that either works, or it doesn't.
This is most definately a Sensor Head problem. As a rule of thumb, it it affects all the heads, it involves the computer, and if it affects only one head, then it is a head problem.
You are simply missing the "Left Turn Sensor" on the toe board. This can be caused by several different problems, including parts and as simple as connections.
First suspect would be the "Toe Board", but you indicated that you have moved it.
Next would be the IR (infared) emitter on the left REAR head. If the emitter has become weak, or blocked, you will have trouble during caster steer. You mentioned that it does not have any trouble during camber; That would be normal. The caster steer function uses a different portions of the toe board sensor to read "Center, left turn, and right turn", so during the "Center", or steer straight ahead position, you would normally experience no problems, even if the left turn function is.
If we can prove that the emitter is doing a fine job, (and we can; a complicated procedure) then we are looking at refreshing, or excercising the electrical connections. I make a great deal of money every year by disconnecting, and reconnecting wires, and solving many problems just like yours. ***IMPORTANT** MAKE NO CONNECTION CHANGES WITH POWER APPLIED TO THE SENSOR HEAD. UNPLUG THE HEADS, AND IF UNSURE, UNPLUG THE COMPUTER!!!
Next, check all the connections at the main board, (Transducer Control Board), and the seating of the EEPROM chips. The chips will walk themselves out of their sockets with temperature changes, through expansion and contraction. Push them back into place, and you may hear a slight "crackling" sound. ***IMPORTANT** MAKE NO CONNECTION CHANGES OR RESEAT CHIPS WITH POWER APPLIED TO THE SENSOR HEAD. UNPLUG THE HEADS, AND IF UNSURE, UNPLUG THE COMPUTER!!!
I am almost certain that you are in need of NO parts. These problems are most commonly caused by connections, either at the cables or the chips. Next highest suspect cause would be the left rear emitter.
GOTO www.Equipmentcity.net to find me. Call anytime for on demand Hunter alignment machine advise, and discount parts.
Posted on Oct 02, 2009
    Sergeant:
  • 250 Answers
Pressure is not getting same on the both side when the wheels turning back .that pressure has to be checked.
Posted on Mar 03, 2009
  • 101 Answers
The sensor may not b level or it needs calibrated
    Brigadier General:
  • 5,158 Answers
How far left do you turn the wheel... sounds to me like all it is doing is indicating how far out of range it is for what you are trying to align
    Sergeant:
    Novelist:
  • 277 Answers
The sensor needs to be checked it is not sensing poroperly.
  • 19,396 Answers
Try resetting the machine to factory, or reinstalling system.
  • Ginko
    Ginko Mar 03, 2009
    That is because of a setting problem , or because the IR sensor is malfunctioning.
    Check that the IR sensor surface is clean, and try resetting the machine.
    Alsto try tripping the alignment machine circuit breaker for ten minutes, this should also reset to factory.
    I need to find more information on the specific model.
  • Ginko
    Ginko Mar 03, 2009
    Finding specific information, like schematics and repair manual on this kind of machine is not easy.
    From description the problem concern the IR sensor calibration, but without a service manual is difficult to fuix the problem.
    The best thing to do is contacting manufacturer using the form here.
2 Suggested Answers
  • 250 Answers
SOURCE: posted by iupholster on Mar
remove and clean and refit the sensor and try if still the same problem.then a manufactures needs to be called for service and replacement.
How to Diagnose an Alignment Problem?
tire wear is a method of diagnosing an alignment problem
abnormal wear on the insides or out sides of the tread indicates a problem with toe in/out and or camber settings
wheel wobble at speed ( 20 mph up ) indicates castor setting problems
steering wheel not self centering after turns indicates castor settings
steering wandering on the road indicates worn steering /ball joints and or alignment settings out
car running sideways ( crabbing)on the road indicates worn rear suspension parts , broken center bolts on leaf springs ,and rear alignment problems which will affect front end alignment
this is indicated by the steering wheel position off center when driving straight ahead
Oct 14, 2016 | Cars & Trucks
Hunter wheel alighment rack RM. What does it mean when the green light flashes?
Hunter Wheel Alignment Lift Repair Manual - Vckystxx.com
vckystxx.com/taggedby/hunter-wheel-alignment-lift-repair-manual/
Hunter Alignment Lift Rack Manual Pdfsdocumentscom, Hugh Dixon Hunter AlignmentLift Rack Manual.pdf ... For Hunter Wheel Alignment Lift Racks. ... Repair ...
Jul 28, 2015 | Cars & Trucks
I just replace the iner e outer tie rods and just had it balance e still the front steeing shakes and sw s ys a little please help i have a 2007 nissan quest whit 95000miles thanks ...
have a wheel alignment done after checking out the front suspension. You may have what is called castor wobble for negative castor settings. Check wheel bearings for condition and adjustment.
Jul 27, 2014 | Cars & Trucks
Excessive steering wheel shaking
Most common indicators are. Wheel alignment ( not enough Castor adjustment) worn tie rod end/s Incorrect size tyres ( you have to have the rim sizes the same on both sides ) even though you noticed a difference Loose steering box / rack or worn rack mount rubbers Probably the noise under the floor as the rack is bashed up and down from the wobble. What you describe is castor wobble and some makers recommend 0 castor when in fact the setting should be 1/2 to 1 1/2 degree positive.
Jun 04, 2013 | 1986 Chevrolet Celebrity
Toe-in, toe-out for mazda bravo 2600,1997 model, dual cab
This must be set on an alignment machine you just can't move the front wheel to what you think is correct, it must be right on. They toe in slightly on most vehicles
Nov 06, 2012 | 2003 Toyota Corolla
What should the front wheel alignment be on an E34 5 series BMW Touring
The only thing you should have to worry about is a full tank of gas and four good tires. The alignment machine (usually a HUNTER) does it all.
May 14, 2010 | 1994 BMW 5 Series
Posted by iupholster on Mar 03, 2009 I have a hunter J111 alignment machine. When I go to set castor and you get to the screen that shows all four wheels are lit up green and even numbers then when you...
try moving the alignment computer backwards with the wheel turned. sounds like the lazer beam is too close and when the wheel is turned it goes out of range,
considering all other aspects of machine work like camber and toe specs.
Mar 03, 2009 | Computers & Internet
Computers & Internet Logo
1,398 people viewed this question
David Payne
David Payne
