Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Top agitator not working properly
The top part of the agitator gets hung up when clothes are in. It seems to work ok when just water but once you put clothes in the top agitator hangs up. It pauses then goes a little than pauses.
  • 163 Answers
You need to replace your agitator dogs in agitator.very cheap fix and easy repair.pop the top off agitator,you will see 1 bolt inside center of agitator,take out bolt and pull agitator.pull agitator apart and in the top part you will see 4 plastic dogs.
Posted on Mar 05, 2009
  • 188 Answers
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Agitator dogs part number is 80040
Posted on Mar 03, 2009
Wash is not agitating properly. Top portion of agitator does not spin and the clothes do not roll over well. Does seem to have a lower unit noise when agitating. Any ideas? thank you, Jeff
inside the agitator there is a set of 4 gears that make the top part of the agitator go back and forth pull off the top and remove the nut inside pull on the very bottom of the complete part then take the top part of the agitator apart from the bottom the install the new new gears by replacing the old ones reassemble and it will work properly
Aug 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Mar 14, 2010 | Kenmore 22622 Top Load Washer
WCSR4170 not agitating
am I to believe that this is a agitator that sits on top of a spindle if so then try and move it by hand as some times the worm and gear cog in the gearbox become sheared or the drive belt is worn and slip easily not giving the power to the agitator I hope that's a start to go on eric
Dec 24, 2017 | General Electric WCSR4170D Top Load Washer
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
My agitator on my whirlpool washer doesn't work properly and that keeps the clothes from getting clean. it seems as something is loose,the bottom part works somewhat but the upper of the agitator's not...
The top portion of the agitator is designed to go in only one direction. The purpose is to keep the clothes moving from top to bottom of the basket. When this "ratchet" action fails to occur, it's due to worn "agitator dogs" (part # 80040) usually caused from overloading. It can be a do it yourself repair, or a very inexpensive service call if a professional is used.
Jun 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wprb8050d0ww does not drain, clothes very wet
eric it seams that its draining ok?thats important.must happen in a certin time frame to get clothes dry.also this thought comes to me check between the tubs with your hand thru the top.if clothing got there it couldnt spin well.but as a repairman i have replaced more ge motors than boards.god bless i hope that helps
Jan 03, 2009 | GE WPRB8050D Top Load Washer
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
542 people viewed this question
Dan Webster
Dan Webster
Sal De
