Siemens 24 in. SL84A305UC Built-in Dishwasher
Problem for Siemens 24 in. SL84A305UC Built-in Dishwasher
No power for my Siemans SL84A dishwasher
By sloandog on Mar 03, 2009
I have a realtively new Siemans SL84A dishwasher, and all of a sudden, the power stopped. I pulled out the dishwasher and tested the plug adn it is fine, so it is the d/w unit. Is there a reset button or a fuse on the unit that will amek this an easy fix? I have not tore into it yet.
Although I think this is unrelated, I drained the hot water heater about 3 weeks ago, but in the process my wife started the d/w. She told me after ward when it no longer sprayed water. I poured some water into the machine and it started right up and worked for the next 3 weeks till all the power went out last night.
Any ideas?Thanks for your time.
Solution #1
posted on May 03, 2009
Not Rated)
jmorris2
Rank: Apprentice
Rating: 0%, 0 votes
Not a solution but a cause for my DW having the same problem. One of the four wires going to the On/Off switch shorted and burned. I never lost power to the unit, as far as I know there is no reset button of fuse. I rewired the unit and ran several washes without overheating or shorting.
Was this helpful?
Yes
No
Popular Solutions for Siemens 24 in. SL84A305UC
Questions and Unsolved Problems for Siemens 24 in. SL84A305UC
Do you recommend Siemens 24 in. SL84A305UC Built-in Dishwasher?
Answer
Answer
well that's basically it. the pump is humming as if it's working, but it doesn't drain. It's been... (More)
Answer
Have the same problem. If anyone can list the key pad, would appreciate! The web site is down
Answer
This weekend the dishwasher stopped cleaning the dishes. The dishwasher sounds like it goes through... (More)
Answer
Dishwasher will not fill. Have checked element and changed thermostat.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Siemens 24 in. SL84A305UC...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
