Question about Canon PowerShot A540 Digital Camera
CARD LOCKED my camera says the my memory card is locked.?? i dont no how to unlock it My A 450 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The camera still indicates card locked with a new card inserted. When i try to take a picture it says "Card Locked!" and it wont let me add a new folder onto the card once its on my computer
  • 3 more comments
  • hymu Mar 18, 2009
    This is Hyma i got a cam with powershot 540, suddenly cam was not working (card is locked) I tried above two solutions but its not working.i tried even for new memory card even though its not working, can you give me any other solution.i will be thank full to you.
  • jspears658 Mar 20, 2009
    I have the same problem I put my card in and the camera says its locked. I can take the card out and put it in my laptop it reads the card fine. Something in the camera will not see the card. Is there any help out there.
  • Anonymous Mar 26, 2009
    yeah same my camera says 'card locked' every time i try to take a pic but it works fine on the computer
  • Anonymous Apr 11, 2009
    HP Photosmart E317 screen states card locked. How do I unlock it?
  • John LeFebvre May 11, 2010
    What happens if you slide the card button the other way, and insert it?
    Then slide it back again and see what happens.
    Scholar:
  • 73 Answers
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
Posted on Mar 03, 2009
  • 423 Answers
Hi Kailey, welcome to FixYa.
Ok, so you know your card is not locked. So, first question...
Did you format the card in the camera before you used it?
If not, format the card in the camera using the menu. Try it and see if it works.
If it doesn't work, turn off the camera and take the card and the battery out. Wait 5 minutes, then put the battery and the card back in, and turn your camera back on. Does that fix the problem?
If not, I would say your card is toast and to purchase another card.
Hope that helps.
Rob
I have a L301 compact. it says on rear screen, card locked. what do i do.
he says that becose your memory card is locked p .....if u dont lock it . just put out the memory card and look at rear has a clip...that locks and unlock the card. Olso chek for a switch that locks and unlocks the card on camera if exists..
Sep 21, 2015 | Samsung Cameras
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Memory Card locked: I changed the memory card in my camera. When I reloaded the previous memory card, the screen says that the "Card is locked". How can I unlock the memory card?
if we are talking about an SD card ...see that in a side ..the card has a slide like button with 2 positions ...locked and unlocked... just unlock it cause it might have been locked when handling it...
Dec 17, 2009 | Canon Powershot SX110 IS Digital Camera...
My memory card is locked
my memory card is locked and i dont know how to unlock it
Aug 21, 2008 | Panasonic Lumix DMC-LS70 Digital Camera
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
CARD LOCKED
try puting the lock thing onto Lock. it worked for me
Apr 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Card Locked
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 26, 2007 | Praktica DCZ5.0 Digital Camera
Memory card locked
I just got done fumbling around with the same problem. All you need to do is take the card itself out of camera and there's a mini switch on the side of the card that slides up and down for lock and unlock.
Oct 01, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot A540 Digital Camera Logo
573 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
