Kenwood KDC-MP228 CD Player
Problem for Kenwood KDC-MP228 CD Player
CD loses its settings when engine is turned off or cd is off
By sharonweekes on Mar 03, 2009
I recently changed my car therefore transferred my cd player my new but each time I switch my engine off after a couple of minutes the cd resets itself losing preset stations and equalizer settings. What is wrong with it???
Comments:
Mar 04, 2009
- I recently changed my car therefore transferred my cd player my new but each time I switch my engine off after a couple of minutes the cd resets itself losing preset stations and equalizer settings. I have been informed that there are two power wires one for memory and the other for key on power and that the memory must have power regardless of key on or off but is there anything I can do to set it or do I have to go to a service shop to get this rectified?? Please help!
Best Solution
posted on Mar 03, 2009
Helpful)
c38hot
Rank: Guru
Rating: 86%, 47 votes
nothing wrong , there are two power wires , one for memory and the other for key on power , memory must have power regardless of key on or off
Comments:
Mar 04, 2009
- if you feel confident in fixing the power wire issue then there are a few ways to do it , one is run a 10-12 guage wire from positive battery terminal to the memory wire on the radio , please use some kind of fuse no farther than 10 inches from battery between the radio and battery 10 to 15 amp , or find a hot wire under the dash and tap into that but it could cause other problems , or consult factory wire diagram for factory radio and use those wires , this would be best
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 15, 2009
Not Rated)
prodac1
Rank: Apprentice
Rating: 0%, 0 votes
that will work
maybe just bad contacts
Was this helpful?
Yes
No
Solution #3
posted on Sep 14, 2009
Not Rated)
lethalslug1
Rank: Guru
Rating: 89%, 25 votes
your positive wires are switched yellow is constant and red is keyd. you have them the other way around.
Was this helpful?
Yes
No
Popular Solutions for Kenwood KDC-MP228 CD Player
Questions and Unsolved Problems for Kenwood KDC-MP228 CD Player
Do you recommend Kenwood KDC-MP228 CD Player?
Answer
Answer
I purchased a used vrvd630 everything work fine. I installed it everything but the DVD works. It... (More)
Answer
he lost the code and can't play cd's i bought it second hand
Answer
I have a 1994 dodge grand caravan se the head lights quit working but everything else seems to be... (More)
Answer
securty code reset on my kenwood kdc-mp43bu
Answer
screen froze while playing the radio, and then a line appeared on the screen.. turned off the car,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
