Question about Vacuums
Electrolux 2100 foot switch
Inherited the above machine with a broken switch// bought the parts to fix how ever once I had taken the machine apart the switch came out in pieces // need picture from a service manual for re-assembly//need to know how the long spring with the plastic insert is placed in the base plate
e-mail picture to jd2002790@yahoo.com
  • bigfam Mar 11, 2009
    I superglued the rocker switch inside (it had broken) but I too am uncertain how the "noodle" and the spring go back in.
The owners manual is HERE: http://www.aerusonline.com/service/manuals.cfm
But it does not show the inside of the foot/power switch
Posted on Mar 11, 2009
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
I need the Manual for #2100 Electroluks vacc
Service manuals for the Electrolux vacuums, including the accessories, are only available to the franchise owners and service techs.
Also, having said that, I don't recommend fixing the switch yourself. Replacing the switch involves disassembly of the canister, which is a bit complicated. Putting it back together correctly, without crimping wires. even more so.
I used to be an Electrolux service manager and have seen vacs brought in in pieces. Customers had succeeded in dismantling the machine, but were unable to reassemble it. Or had cracked or broken a piece. This makes the repair more expensive.
Or machines were brought it that had been reassembled incorrectly and wouldn't work. Or worse had shorted out due to crimped or incorrect wiring.
I strongly suggest taking the vacuum to a repair shop that is familiar with the older Electrolux vacuums, in this case the plastic models.
Mar 06, 2014 | Electrolux hose 2100 series diplomat
Shuts off (overheats) after 10 minutes. Protecto relay? How to take apart?
Your machine is what's called a "Special Model" and needs to be disassembled upside down in a form fitting tray, by removing the two side rubber bumpers, then taking off the bottom and finding the part that shuts it down. The best thing to do is to take it to an Electrolux repair shop and let them handle it. They have the trays and they're trained in the way it comes apart properly;
Nov 09, 2013 | Electrolux electric hose models 2100
Cord will not reel in
Try standing machine upright to rewind. If it doesn't, it should be taken to a shop, authorized Aerus Electrolux preferrably, and a trained service tech allowed to fix it. There may be a broken piece in the cordwinder that needs replaced and it's cheaper to let them fix it in the first place than to take it apart and not be able to put it together again.
To find a shop near you, simply follow the directions on the following site.
http://www.aerushome.com/storelocator/
Oct 16, 2010 | Electrolux C101 Bagged Canister Vacuum
I have an electrolux 2100 and it won`t shut off when i depress the top button? thank you
You need to replace the switch button:
Take out the bag and keep the door open.
While the bag door is still open, turn the machine upside down so you are looking at the serial number.
Pull the cord out one foot.
Use a puddy knife and put it between the rubber side rails and the **** end of the machine.
Use a hammer or malett to hit the putty knife from the back of the rubber bumber toward the bag door.
Pull the rubber bumber stright out on both sides.
Once both bumpers are out pull the lower body of the canister from the **** end toward the intake of the machine.
Once the bottom is open you can then service the motor, cord winder, switch, and all other components.
For all the parts to fix the machine visit: http://evacuumstore.com/c-69-electrolux-accessories.aspx?manufacturerfilterid=0
Mar 17, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My Electrolux Aerus auto rewind chord mechanism is broken. Is there an easy way to remove the back of the canister to replace or fix the spring there?
Feb 28, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Don't know where to turn on the vacuum of the electrolux guardian. Bought it used. Can you help?
Usually these types of vacuums havve a foot operated switch that is part of the body and kind of blends in with the body of the vacuum, they may also have a switch on the handle.
Feb 03, 2010 | Electrolux Guardian Bagged Canister Vacuum
How to open legacy canister
Dec 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
I'm looking for a used or reasonable priced motor for my Electrolux LE, series 2100 vacuum. LEE is shown as model but no searches respond to this as a model number. Help. Thanks, Max
Unfortunately, the Electrolux company as such no longer exists. Eureka bought the name "Electrolux" and started making Eurekas with Electrolux stickers on the outside. This makes for some confusion when looking for parts.
The company that used to make Electrolux is called Aerus, and they may still be manufacturing parts for those machines, but true Electrolux parts are getting scarce. I'd check the Aerus website and see if they have a way to get those parts, or at least a cross-reference.
-R
Aug 16, 2008 | Electrolux Vacuums
Vacuums Logo
217 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
