Question about Vehicle Parts & Accessories
I need code for radio on volkwagen golf 1998?
  • 95 Answers
If you dont have it in your glove box in the owners manual or with the papers with the car than you going to have to call your local volkswagen dealer and talk to someone in tech services and than give them your serial/vin number of the car and they can look it up for you then.
Posted on Mar 03, 2009
The engine yellow light is on on my 2003 volkwagen golf
This indicates a engine fault code has been stored in the computer. Aquire a scanner or electronic diagnostic tool to retreive codes from ECM. Usually Autozone or O'Reileys will reas rhem for you free of charge.
Mar 07, 2014 | 2003 Volkswagen Golf
Vw golf 1998 safe code 1000 how to change it
1 enters the 1st place value, 2 enters the second place value, 3 enters the 3rd place value, 4 enters the 4th place value. press the buttons as required to enter your code. if you enter it wrong and it locks up, you will have to leave the ignition and the radio on for 1 hour.
Jan 18, 2014 | 1998 Volkswagen Golf
1998 volkwagen golf 1998 start when it's cold
bypass the starter motor, see the diagrams attached, and see what happen, you will have a new vision with this.
God bless you6b087c64-a124-4ae9-a2f7-033456b4a907.jpg63121238-77ae-403b-9905-dd6a87e59f46.gif
Jul 23, 2013 | Cars & Trucks
Golf 1.6 1998 auto radio code needed. any chance?
the first owner may have written it down in the service book.if not, it is,because of its age,better to replace it with a radio/cd unit.inside cover of the service book is where it shoul be, a little sticker.dealers DO NOT KEEP CODES.
Mar 01, 2010 | 1998 Volkswagen Golf
1994 volkwagen golf, only starts when starter fluid sprayed into air intake. After starts runs fine. after warmed up, still doesn't start without fluid
Is this a diesel? If so it could be fuel filters because that is classic signs of a fuel filter needing changed.
Oct 12, 2009 | 1994 Volkswagen Golf
Loud clicking noise whenstarting vw golf 1998
it could be noisy lifters... do you have clean oil in there oil is it black.
dirty oil will make volkwagens make lots of engine noise.
it also could be a spark arcing to metal. check to see all your spark plug wires are pushed all the way down and dont have cracks in them.
Jul 09, 2009 | 1998 Volkswagen Golf
My 1998 volkwagen golf is over heating, the water pump and the gasketts have been changed, but its still alarmingly high. What could be wrong???
i have an identical problem. water temp goes up. oil temp climbs then drops then goes higher than usual. i checked my water pump, replaced thermo switch, replace thermostat, refilled with new oil and oil filter, refilled radiator with new coolant. still the same. i suspect the last thing is a warped cylinder head, but it could also be just my radiator cap that is not releasing/retaing the proper pressure, because there is quite a bit of pressure in the water system when i open the cap. i suspect yours looks identical? the last thing after that (before checking the cylinder head) is the two temperature sensors on my top radiator hose. some cars have one, but that could be messed up as well. hope this helps
Mar 20, 2009 | 1998 Volkswagen Golf
1997 Volkwagen Golf K2 Starting Problem in Winter
possible coolant temp sender or crank sensor,have you got fuel at the plugs and a spark,one quick check is to disconnect the temp sender this will then put it into a cold start fuelling....
Jan 29, 2009 | 1997 Volkswagen Golf
Golf 54 plate mk v radio turning on
Volkwagen UK's official response, October 6th 2008: keep a music CD in the slot. Which has to be better than paying nearly £600 to replace the radio.
Let's hope it works!
Jul 03, 2008 | 2004 Volkswagen Golf
VW Radio unlock code
i need to find the code to get my radio off of safe mode for a 1998 volkwagen golf?
Jun 24, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
