Question about Sony KDF-50E2000 50" HDTV
Sony Shadow on top of screen
I have a Sony Bravia KDF-50E2010 rear projection TV. There is a 1 inch deep pinkish coloured shadow across the top of the screen. Can anyone advise if this can be fixed by adjusting any of the menu settings.
  • 3 more comments
  • wakelinsherr Mar 08, 2009
    We have a pinkish/redish 2 inch shadow going across the top of our television. Is this something that has to be repaired?
  • Jaefran Mar 10, 2009
    I have a Sony WEGA KDF-50E2000 rear projection TV. There is a 1 inch deep pinkish coloured shadow across the top of the screen after I replaced the lamp. Any ideas on the problem is?
  • dcdon86 Apr 26, 2009
    my sky hd box switched itself off and the screen went green,i unplugged it and got it going again but afterwards i noticed a thick pink line across the top of the screen.i thought it was a problem with my sky box but the line is there on all the av settings and arial,its very annoying.the tv is a sony KDF-50E2010 and its nearly 3 years old.I took out a 4 year extended warranty when i bought the tv.i wonder if it will cover getting it fixed or is there any way to fix it myself first,thanks.
  • benson1977 Apr 26, 2009
    I have a Sony KDF 50 e t.v and I have faint two green lines going across the screen. Any one know how to get rid?? Its very annoying. The lines are at the top about 2 inches down.
  • butnpsher1 May 04, 2009
    I have a 2000 model and it only started showing up after I replaced the lamp/bulb. It is called an Optical Block.. something or other. I called Sony 2 days ago and they are running a special program for the E2000 series. IF you qualify you can upgrade to a new tv for a hugely discounted price, or they can replace your tv for a slightly smaller one free of charge or try to repair the one you have free of charge. It is worth it to call Sony and find out if you might be able to get into the program. It is called the E2000 Special Program. Our TV is a little over 2 yrs old and we qualified. Good luck
  • 87 Answers
Please call sony Optical Block warranty extended to June 30, 2010
Posted on Apr 14, 2009
  • 3 Answers
Well this is the fix for the usual Ghosting problem....
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone
Posted on Mar 16, 2009
  • jaynehelen Mar 10, 2011
    i HAVE A SONY KDF 50-E2000, AND I TRIED THE SEQUENCE TO BRING UP SERVICE MENU,BUT THEREIS NO GREEN LETTERING ON IT.
  • rostit Oct 13, 2014
    This is an LCD TV. there are no convergence settings.
    Master:
  • Sony Master
  • 625 Answers
You have a bad polarizer. LCD TVs have no convergence ICs. stop giving bad advice.
Posted on Oct 13, 2014
  • 4 Answers
The Fix for this TV lies inside, very much inside. when you fully take it apart, there is an aluminum bezel around the screen you have to take that off, and then you will see these goldish tape strips, they are very crapply attached, its hard to solder plastic tape so the connections crack from streches, and some tvs once the tv has warmed up after 10 mins, you can shut it off and turn it on and will be fe fine. You really have to tape them down or insert some rubber tube in between the bezel. Its a delicate operation because it is very very easy to break the lcd. BUT dont forget, there is connection on the bottom as well. make sure bottom right is pressed down, the connection tape that is.
Posted on May 17, 2013
  • 1 more comment
  • Peter Kiryluk
    Peter Kiryluk May 17, 2013
    PS, its Vol UP on this for the service menu, and if your having this common problem, that i wrote about, you will see NO CODES in the service screen. BUT it is a pain to get to the tapes, you better get
  • Peter Kiryluk
    a couple cups for screws, and 2 markers mark where the screws go once inside, because you will foget.
  • Peter Kiryluk
    Note a guy on the top talking about the menu, that probably will work, because i imagine if u tell the tv to shift which pins it uses, the problem will go away.
  • 40 Answers
Https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6812907&smodel=KDF50E2000 this is the part you need sorry to be the bad news you tv does not have convergence ic's
Posted on Mar 10, 2009
  • 75 Answers
Sounds like a convergance problem. I would say that the ics are going out you probley will have to have it reparied dont think you will be able to adjust it out. Soory whish it was that easey.
Posted on Mar 03, 2009
Sony bravia
I had a different problem with a different model. My HSDI ouput stoped working. I went to SONY Live Chat with service tech. and he had me download new software to my BRAVIA and it fixed the problem. I would check it out. Go to http:esupport.sony.com.
Hope this helps, Steve
Jun 30, 2012 | Sony KDF-50E2010
My TV is a Sony Grand Wega KDF-42WE655. I purchased the TV new 5 1/2 years ago and have had to replace the bulb once at the beginning of this year. I have a blue shadow on the bottom right corner on the...
The blue shadow is a sign of a bad light engine. this is a common problem for this model. Fixing this type of problem is quite expensive. Light engine Costs you several hundred of dollars nearly to the price of new TV set.
Nov 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Bravia LCD black shadow screen
You may ahev failing T-CON board, try having a small fan blowing at the vent on the back of the TV. If you can post pictures it will help a lot.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 28, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Sony bravia 50 inch projector tv kdf-50e2010
how do you remove the screen from sony kdf 50e 2010 i have removed screws from top and sides of tv but cant see how to release bottom of screen
Nov 07, 2007 | Televison & Video
Sony KDF-50E2000 50" HDTV Logo
2,003 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
