Question about Rainbow E series Canister Wet/Dry Vacuum
I have a Rainbow E2 series, 23, for about 3 years. It has now a different and very aloud sound coming fron around the motor and also I feel it is not suctioning with the same power. If I close the hose like closing totally the suction entrance, the sound comes normally. I will appreciate if some one can tell me what to do, becouse there is not a Dealer in my Contry any more. Thank You. Pierre Chabaneix - Lima-Peru pierrechc@hotmail.com
    President:
  • 389 Answers
Hi there, Pierre! Sorry, but I think this is bad news. From your description, I suspect that a motor bearing has failed. The only way to fix it is to replace the motor, and without a dealer in your country, that could be a big problem. The Rainbow design does have attractive features, but always working wet is bound to have its problems. My best advice is to buy yourself a good quality bagged vacuum cleaner. Forget about bagless, they have too many problems! I hope this is helpful. Good luck!
Posted on Mar 04, 2009
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
Looking for replacement component for motor controller board, a capacitor that is in series with the AC input line.
Unfortunately Rainbow does not offer this part by itself, they only make the computer as a complete assembly. Rainbow E2 controller 120v You can try contacting local vacuum shops and see if they have any broken Rainbows with good controllers that they would be willing to sell only that part to you.
800-775-6586
GoodVac com
Feb 10, 2015 | Rainbow Vacuums
My rainbow vacuum e series won't turn on.
it could be the switch . or brushes
Feb 01, 2015 | Rainbow Vacuums
E series Canister Wet/Dry Vacuum: My tank foamed up into the motor and now the rainb...
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Have a rainbow e-2 that was running and quit.
Thank you,
Ralph
Apr 25, 2010 | Rainbow E series Canister Wet/Dry Vacuum
No power
You must have a late model 2006 or newer E2 two speed Rainbow vacuum that has the white foam padding in the canister, to dampen the sound of the motor, and has a red light on the computer board.
I hate to tell you, but your computer is most likely the problem, and is out on your E2 two speed vacuum.
The only solution is to get a new computer for it.
It is realy not worth replacing it, because it may also be the motor. The E2 is a very high tec system, and is not like any other vacuum. When you turn it on, you are not turning on the vacuum. You are turning on the computer, which is controling everything.
I could supply you with another canister, if you are interested.
Thank you,
Ralph
Feb 20, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Feb 18, 2010 | Rainbow E series Canister Wet/Dry Vacuum
E2 gold series - makes loud noise on start up
That is normal. All E2 two speed Rainbows make that sound. It is because it has a brushless motor that the computer is controling, and the computer is controling everything. The motor rotor has no coils on it on the rotor, which is very small and light, and the computer gives it a small power boost when you first turn on, then increases the power until ir reaches full speed.
Thank you,
Ralph
Jan 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I want to take the vac apart to clean around the motor ?
likely a break in your cord somewhere. if you have a ohm meter check it otherwise tale it to a vac repair shop
Oct 25, 2008 | Rainbow E series Canister Wet/Dry Vacuum
I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Jul 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
252 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
