I cannot get internet access with my Wii. My PSP will get access sometimes. But the connection dies while I am using it.
  • 4 more comments
  • Barb Jackson
    Barb Jackson Mar 04, 2009
    I reseting the router and reinstalling the cd,has not solved the problem.
  • Barb Jackson
    The advice I received : reset the router,reinstall the set up cd. The router still is not working.
  • Barb Jackson
    Yes I have reset the unit. More than once!!
  • Barb Jackson
    The Wii system and the router were setup to
    converse with each other, when the Wii was
    bought. This problem between the Wii,PSP connecting to the router is a recent problem
    that started when I had to replace my modem
  • Barb Jackson
    The position of the Wii and the router have no effect on the problem
  • Barb Jackson
    I guess I need to buy a new router Thanks anyway!
  • 6,487 Answers
You need to do a firmware upgrade on your router and that will fix the problem, but if after that still same problem better get a new router then...
Posted on Mar 04, 2009
  • 15,935 Answers
Hard reset everything.
Power down and unplug (except P/C) every component in the network for 5 minutes for a hard re-set... Then plug in/turn on in the following order -
  1. Modem - wait until fully powered on before moving on.
  2. Router - wait again until fully powered on before going to next step.
  3. Main P/C - again - wait until windows loads fully.
  4. Wii
  5. PSP
  6. Other
This will allow each peripheral to connect at the same address without problems.
If you have a G speed router - you may think of upgrading to N for online gaming.
G speed have larger wavelength frequency and are easily dropped thru walls, another router near your home, or interference from phones powerlines etc.
Thanks for using FixYa - a FixYa rating is appreciated!!
  • 44 Answers
Hi!
Try refreshing available wireless networks! Good luck, hope this is helpful!!
  • 408 Answers
You need to reset your router.  There should be a reset button on the back.  Do this and redo the cd and reset up your Wii.
  • 479 Answers
  • orking with the SPI Firewall
    If you are able to log in and disable the router or gateway's firewall, you may be able to get the Wii console connected online. To do this you may need to get a "super user" password from your ISP.
  • Updating your Wii console
    If you use an ISP that prevents the firewall or SPI firewall setting from being adjusted, or if you prefer not to adjust the router's firewall, updating your Wii console with the latest system menu may resolve the console's ability to connect with Nintendo's servers. (This may be especially true if your Wii has not been updated to Wii Menu 2.2* or higher. Link here for information on determining which Wii menu version you have.) To download the system update to your Wii system, you will need to successfully connect your Wii console online. If your current connection through your ISP-provided router is preventing a connection, you will need to find an alternative online connection, such as taking your Wii console to a friend's house where there is a compatible internet connection. If this option is not available to you, link here for information on other options. If after performing this update you are still experiencing problem
    Sergeant:
    Champion:
  • 224 Answers
Try resetting the router. this is by turning it off for a few minutes and back on. else it could be a bad router
  • 916 Answers
If you bring the wii closer to the router does this still happen?
    Brigadier General:
  • 8,619 Answers
Hi!
You need to search for your access point from your wii console and then put in your security settings. You have to search for wireless networks again, based on the interface, it will not automatically connect to any of them, you have to set them up first.
Are you using a full version of internet channel which is a version of the Opera 9 Web browser? Try moving your wii closer to your router to improve the signal.
    Brigadier General:
  • 3,614 Answers
have you try to reset the unit. make sure there no obstruction on the signal
    Genius:
  • 1,550 Answers
Initial press reset button on router .
Install the cd and set up for wifi .
  • 19,396 Answers
Check that your network signal is strong enough
  • Ginko
    Ginko Mar 04, 2009
    Check that the problem is not just a weak signal from the network, remove any possible cause of disturbance (metal panels, TV etc.) between the Wii and the router.
    If you still get the problem, it may be an issue with the Wii network adapter, in this case call Nintendo support, they may offer you a replacement.
  • Ginko
    Ginko Mar 04, 2009
    I thought that the router was working.
    If the router is not working at all, not even with a wired computer, then you need to call your Broadband service provider, and follow the step by step indications to set up your network, with the settings they give you.
    If you tell me your provider and location I can find the number.
I what to know how to put internet on my wii
From the wii home menu...
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
Jul 19, 2011 | Nintendo Wii Console
Tip
How to connect your Nintendo Wii to the internet
In this tips and tricks guide I will go over the steps you will need to take if you wish to connect your Nintendo Wii to the internet. If you want to connect wireless you will need to be within range of a wireless access point. If you wish to connect via a wired connection(Ethernet to modem or Ethernet to router) you will need a Wii LAN adapter which is sold separately.
-Power on the console and press the A button to reach the Wii menu. At the menu, use your remote to select the Wii button at the bottom left.
-Now select "Wii settings"
-Now, hit the arrow on the right side of the screen to go to the next page and select "Internet"
-Select "Connection 1: none"
-Select "Wireless Connection" then select "Search for An Access Point"
-Select "OK" then the Wii will display all the wireless access points(wireless routers) that are in range.
-Select the wireless access point you wish to use.
-If the access point requires a security key, you will need to enter this key in. This key is set when you first configure your wireless router.
-Select "OK", then "Save Settings", and then "Yes".
At this point your Wii will now test the internet connection.
If you are using a Wired connection then you can connect the Wii directly to the router or modem and not use WiFi. Wii LAN Adapters are sold separately. If you have the LAN Adapter, follow the steps above up to the point were you select a connection type. You will select "Wired" instead of "Wireless. The Wii will now test your internet connection.
I hope this guide has helped you connect your Wii to the internet. Enjoy!
Regards,
G33k
on May 13, 2011 | Nintendo Wii Console
I am trying to access the internet to get netflix on a used Wii. It is saying error code 51420. What do I do?
Sometimes this happens because servers go down for nintendo. If this problem persists it might be caused by a third party adapter that is used to connect your wii to the internet.
May 30, 2011 | Nintendo Wii Console
Activate internet
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the psp" button. Now, select "psp Settings" to access the "System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point." Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours Select "OK," "Save Settings," and then "Yes."The psp console will run a connection test with your wireless network when the test is completed. You should see the following screen.Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the psp will begin to download any available updates.
Dec 24, 2010 | Sony PlayStation Portable (PSP) Console
Connecting my wii to the internet
to connect your wii to the internet connect to the following link or read the following instructions
http://systemsetup.nintendo.com.au/Connecting_Online
to connect your wii to the internet you will need to provide a wireless internet access point for it to find. you will need:
a computer connected to broadband internet
a wireless router OR Nintendo Wi-Fi USB Connector OR Wii LAN Adapter
your wii console to be nearby all of the above
If you are using the LAN Adapter you must plug the USB connection into the back of your wii console and the other end to your internet modems ethernet port. (follow steps below)
if you are using a wireless connection follow steps below.
Turn on your wii and on the main menu select 'wii' in the bottom left hand corner
On the next screen, select 'wii settings'
In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
Select 'connection settings'
select an open connection indicated by 'none'
select the corresponding option, Wired or Wireless connection
Wired:
Wireless:
Select the corresponding option, Search for an access point or Nintendo Wi-Fi USB Connector
the wii will search for an access point, select the access point you wish to connect to, and save the settings
The wii will now do a test connection and do a system update, the wii will now use that connection point to acces the online services
hope i helped!!
Sep 19, 2008 | Video Game Consoles & Games
HOW TO GET INTERNET ON PSP THE EASY WAY
Well then, give me more details like the modem, the router and type of pc.
Sometimes, I can't connect to the internet but only the router, so you have to do it manually... Like I did... I'm still testing My DSi, My Wii is semi bricked, it doesn't show the Wii Settings Menu...
Apr 14, 2008 | Video Game Consoles & Games
PSP internet problem ongoing
has it ever connected to the wireless router if not try changing the settings of sercurty wpa-psk
Sep 21, 2007 | Sony PlayStation Portable (PSP) Console
PSP Internet Problem Cont'd
Dont forget to check your WLAN switch on the left hand side, it must be slid to the up position.
Sep 16, 2007 | Sony PlayStation Portable (PSP) Console
Psp internet problem
You need to enter the wep key, ONLY if you have wep enabled on the wireless connection.
Sep 15, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
David Payne
David Payne
