Question about U-Line Icemaker
Small U-Line ice maker freezing but not making ice
Water fills makes ice but does not dump motor works and activates switches but i cant get it to make ice on its own
  • 3 more comments
  • waveoh Mar 04, 2009
    model number is B198. What triggers the cycle? How does the unit know when the ice is ready to dump?
    I figured it out thermostat was not working so compressor wasn't shutting off thanx
  • las_office May 11, 2010
    U line Model 95 icemaker
  • steve
    steve May 11, 2010
    We are almost there.
    U-line has a model number B1-98 and a model number B198.
    Please clarify your number.
    Thank you.
  • steve
    steve May 11, 2010
    With a model number I can help you.
  • 400 Answers
It is possibly your havester thermostat which is faulty or the sensor bulb not positioned correctly on the evaporator tubing. The other common thing is of course the defrost timer which could be faulty
Posted on Mar 05, 2009
Freezing Water line
Hello
The problem here is your water valve. It does not shut off all the way and allows very slow water flow through the water line. It is so small that it freezes in the supply tube causing a blockage. When your ice maker calls for water the pressure from the blockage pops the line out causing your leak.
You need to replace your water valve. Dual valve at the back of the fridge.."water inlet valve")
Jul 18, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Not making ice cubes
Fill ice maker with tap water and let freeze. If ice dumps and water does not refill tray then the water control valve is defective. If ice remains in ice maker then ice maker is the problem.
I think Amana still uses the Whirlpool made ice maker. It consits of a mold, a paddel to remove the ice, a motor to drive the paddel and a cam. The electrical part consists of mold, thermostate or sensor ( use to be thermo-disc), micro switches, 1 to hold the unit running 2nd to alow water to flow at a certain time and a mold heater. Sequence of operation: Thermostate senses mold is cold, activates motor to turn paddels and cam. As cam turns it depresses a micro switch to hold motor running. Motor cam and paddel turn, mold heater is also turned on. As mold warms the paddels scoup out the ice. Contunes to turn until a spot on the cam activates another micro switch to allow water in. Motor continues, as cam reaches a spot it releases the micro switch for water andthen the switch holding the motor on and unit shuts off ready to do it again.
Sep 09, 2010 | Amana ARB2257C Bottom Freezer Refrigerator
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
No water going into ice box of icemaker. Motor seems to be working ok. Checked hose not snagged.
Most times that will be the water control valve on the rear of refrigerator and most times they come as a pair or dual one side for water dispenser and other side for the ice maker. You can test to see if the ice maker is defective by turning switch on and fill with tap water. When it freezes and dumps but no water refills the ice maker then the valve for the ice maker side is defective and will need to be replaced as a pair. If you fill ice maker with water and it freezes and then does not dump then most likely the ice maker is defective.Thnks Sea Breeze
Dec 13, 2009 | Samsung RS2534 Side by Side Refrigerator
Ice maker does not make ice. Water supply works, but ice machine is dry.
if it is the ice maker in the door, it's a bad ice maker....we do a lot of them
Nov 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
Sep 16, 2009 | Refrigerators
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker won't send water to unit. Solenoid is good
Make sure the fill tube where the water goes into the ice mold is not full of ice. Your old valve may have been leaking and it will freeze in the fill tube. Other than than maybe start the ice maker working by filling it with water and see if it dumps and refills.
You can swap the wires on the inlet valves and try the water dispenser. The water should go to the ice maker letting you know the valve works and the line is clear.
Aug 15, 2009 | Refrigerators
U-Line Icemaker Logo
207 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
