Expeirenced power surge in house. Burned out half of appliances and All surge protectors. Transformer on B&O turntable was tourched but now fixed. Tape deck, CD's, DVD's, and sound from TV into stereo speakers all work fine at all volumes. Cannot play any vinal. Severe distortion when using turntable. Also tried brand new Denon turntable as test. Same thing, distortion at even low volume.HELP
  • 10,594 Answers
Please check or use another connecting cable between turntable and amplifier.
If distortion is still there then Phono input (truntable input ) circuit is bad and you need qualified tech to look it.
Posted on Mar 03, 2009
    Sergeant:
    Novelist:
  • 277 Answers
Did you got checked all the internal wiring connection.
I have a 60' lg..flat screen..walked in house.heard lighting in a distance.my daughter turned the tv on..then it shut off..think lighting hit it..any way to fix//
Always a good idea to have a "surge protector" between the wall outlet for electrical and the appliance plugged into it. A surge protector will prevent a surge that could damage your set. $10.
Feb 16, 2015 | LG Televison & Video
Titan Troubleshooting
Check for small fuse on circuit board:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Water heater circuit boards are NOT protected from surge. And reset button does not protect from surge. Nearby lightning can put out any household appliance, especially since more of these things are electronic instead of mechanical.
Install single-use whole house surge protector and replace it after each surge event instead of replacing appliances.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
The quickest solution for tankless is to replace whole thing with more reliable tank-type electric heater for $275 from local box store.
Jun 18, 2013 | Water Heaters
MALIBU 200 WATT IRON CORE TRANSFORMER MODEL NO 8100-0200-01 LIGHTS WONT TURN OFF
Plug power pack into cheap wall timer, and that will operate lights until warranty is resolved with Malibu or product-seller.
Simple power outage, or nearby lightning strike, can cause surge that will knock out digital timers. And knock out analog series power packs too.
You probably need receipt for warranty claim.
This timer is not shown on Intermatic site, and not subject to Intermatic 5-year warranty, but certainly Malibu must have a warranty of unknown length, and a corresponding claim procedure.
Double-check your installation, and additional resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Whole-house surge protection is hot item among folks these days since so many household items are now electronic, including appliances, washer-dryer, water heaters, timers, etc.
This will protect both 120Volt and 240Volt circuits, although it is unknown if your timer failed because of surge..
Sep 29, 2012 | Hardware & Accessories
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
Numark Axis 9's wont turn on
1. Check for internal fuse.
2. Check the power transformer.
3. Check the rest of the power supply.
Aug 11, 2009 | Audio Players & Recorders
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Zenith R56W36
your main power supply has been burned out. make sure all electronic are protected by a surge protector in the furture
May 02, 2009 | Zenith R56W36 56" Rear Projection...
I have Philco 841.169 model and when I press the phono button so I can play an LP, it keeps showing the word "LINE" what does this mean and how I can start my turntable?
about 3% of the time the 'brains' get scrambled, try unplugging it from the wall for a few minutes, sometimes this will 'fix' it.
if so, a power surge from your power company might have got it confused, if the problem continues try a surge protector power strip.
Dec 20, 2008 | Philco 841.169 Turntable
Amana bottom freezer refrigerator-
No appliance manufacturer recommends the use of aftermarket surge protectors. They pull high amperage at start and exceeds most protectors. You can have a whole house surge protector installed in your main panel by a licensed electrician. They are the only method that works when serious surges happen.
Nov 24, 2007 | Amana ABB2227DE Bottom Freezer...
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
15 people viewed this question
 Grubhead
Grubhead
