Question about Panasonic KX-TG1033S Cordless Phone
One of the handsets does not work. the other two handsets are OK
The defective unit gets no dial tone, will not page from the base unit, can't dial or talk on it. Battery is fully charged. Tried to re-register it to the base unit, but that did no good.
    Problem Solver:
  • 18 Answers
Probably defective unit.Try and get it replaced.
On another note, when these phones act like they are going to **** out on you in about a year (manufacturers often use the lowest bidder for batteries on these), replace the batteries with Energizer rechargeable equivalent. That exact scenario worked great for me and my older Panasonic setup is running 4 years strong on the Energizers.
Posted on Mar 03, 2009
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
Tip
Fixing the handset link to base unit of Panasonic KX-TG4500
After the base unit died I was able to restore power by switching out the power adapter of one of the handsets with the one on the base unit. However, when the power was restored to the base, none of the handsets that previously worked were getting a dial tone. I could only use the phone from the base unit. To fix the handsets I first reset the base unit by pressing the reset button with the tip of a pen on the bottom of the base phone then momentarily removed and reinstall the battery on each of the handsets to allow each to reset individually. In doing so, I got the dial tone back on all previously linked handsets without having to reregister them.
on Mar 23, 2010 | Lands Phones
Selecting dialing mode
The directions for changing the dialing mode from tone to pulse can be found in the owner's manual for the main base unit.
Press the [MENU] button then choose "Set tel line". Then choose "Set dial mode", then choose Pulse or Tone and press [OK].
Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF#page=14
Jun 28, 2014 | Panasonic KX-TGA101S Cordless Handset
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
No Dial Tone
I have found this free link on BT site for you
http://www.shop.bt.com/content/uni2/documentation/498n/025455.pdf
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
May 08, 2007 | British Telecom Synergy 2110 Cordless...
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
107 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
